CC [M] fs/xfs/libxfs/xfs_ialloc.o
CC [M] fs/xfs/libxfs/xfs_ialloc_btree.o
CC [M] fs/xfs/libxfs/xfs_inode_fork.o
CC [M] fs/xfs/libxfs/xfs_inode_buf.o
CC [M] fs/xfs/libxfs/xfs_log_rlimit.o
CC [M] fs/xfs/libxfs/xfs_sb.o
CC [M] fs/xfs/libxfs/xfs_symlink_remote.o
CC [M] fs/xfs/libxfs/xfs_trans_resv.o
CC [M] fs/xfs/libxfs/xfs_rtbitmap.o
CC [M] fs/xfs/xfs_aops.o
CC [M] fs/xfs/xfs_attr_inactive.o
CC [M] fs/xfs/xfs_attr_list.o
CC [M] fs/xfs/xfs_bmap_util.o
CC [M] fs/xfs/xfs_buf.o
CC [M] fs/xfs/xfs_dir2_readdir.o
CC [M] fs/xfs/xfs_discard.o
CC [M] fs/xfs/xfs_error.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_inode.h:22,
von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:28:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c: In Funktion »xfs_swap_extents_check_format«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/libxfs/xfs_inode_fork.h:90:42: Warnung: »<<« in booleschem Kontext, meinten Sie »<«? [-Wint-in-bool-context]
90 | #define XFS_IFORK_BOFF(ip) ((int)((ip)->i_d.di_forkoff << 3))
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:1668:21: Anmerkung: bei Substitution des Makros »XFS_IFORK_BOFF«
1668 | if (XFS_IFORK_BOFF(ip) &&
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:1678:21: Anmerkung: bei Substitution des Makros »XFS_IFORK_BOFF«
1678 | if (XFS_IFORK_BOFF(tip) &&
CC [M] fs/xfs/xfs_export.o
CC [M] fs/xfs/xfs_extent_busy.o
CC [M] fs/xfs/xfs_file.o
CC [M] fs/xfs/xfs_filestream.o
CC [M] fs/xfs/xfs_fsops.o
CC [M] fs/xfs/xfs_globals.o
CC [M] fs/xfs/xfs_icache.o
CC [M] fs/xfs/xfs_ioctl.o
CC [M] fs/xfs/xfs_iomap.o
CC [M] fs/xfs/xfs_iops.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c:21:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c: In Funktion »xfs_growfs_data_private«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/libxfs/xfs_format.h:768:17: Warnung: Zugriff auf die Adresse des gepackten Elements von »struct xfs_agfl« führt möglicherweise zu einem nicht ausgerichteten Zeigerwert [-Waddress-of-packed-member]
768 | &(XFS_BUF_TO_AGFL(bp)->agfl_bno[0]) : \
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c:279:28: Anmerkung: bei Substitution des Makros »XFS_BUF_TO_AGFL_BNO«
279 | agfl_bno = XFS_BUF_TO_AGFL_BNO(mp, bp);
CC [M] fs/xfs/xfs_inode.o
CC [M] fs/xfs/xfs_itable.o
CC [M] fs/xfs/xfs_message.o
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c: In Funktion »xfs_handle_to_dentry«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:182:25: Warnung: die Umwandlung eines gepackten Zeigers auf »struct xfs_fid64« (Ausrichtung 1) in einen Zeiger auf »struct fid« (Ausrichtung 4) führt möglicherweise zu einem nicht ausgerichteten Zeiger [-Waddress-of-packed-member]
182 | xfs_handle_acceptable, NULL);
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:37:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_export.h:62:8: Anmerkung: hier definiert
62 | struct xfs_fid64 {
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.h:21,
von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_linux.h:94,
von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs.h:32,
von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:18:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/exportfs.h:105:8: Anmerkung: hier definiert
105 | struct fid {
CC [M] fs/xfs/xfs_mount.o
CC [M] fs/xfs/xfs_mru_cache.o
CC [M] fs/xfs/xfs_stats.o
CC [M] fs/xfs/xfs_super.o
CC [M] fs/xfs/xfs_symlink.o
CC [M] fs/xfs/xfs_sysfs.o
CC [M] fs/xfs/xfs_trans.o
CC [M] fs/xfs/xfs_xattr.o
CC [M] fs/xfs/kmem.o
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_xattr.c: In Funktion »xfs_xattr_put_listent«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_xattr.c:186:9: Warnung: »strncpy« Ausgabe möglicherweise abgeschnitten, beim Kopieren von 5 bis 9 Byte aus einer Zeichenkette der Länge 9 [-Wstringop-truncation]
186 | strncpy(offset, xfs_xattr_prefix(flags), prefix_len);
CC [M] fs/xfs/uuid.o
CC [M] fs/xfs/xfs_log.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_linux.h:53,
von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:19:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/module.h:130:13: Warnung: »init_module« legt weniger eingeschränktes Attribut als sein Ziel »init_xfs_fs« fest: »cold« [-Wmissing-attributes]
130 | int init_module(void) __attribute__((alias(#initfn)));
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1942:1: Anmerkung: bei Substitution des Makros »module_init«
1942 | module_init(init_xfs_fs);
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1826:1: Anmerkung: Ziel »init_module« wurde hier deklariert
1826 | init_xfs_fs(void)
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/module.h:136:14: Warnung: »cleanup_module« legt weniger eingeschränktes Attribut als sein Ziel »exit_xfs_fs« fest: »cold« [-Wmissing-attributes]
136 | void cleanup_module(void) __attribute__((alias(#exitfn)));
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1943:1: Anmerkung: bei Substitution des Makros »module_exit«
1943 | module_exit(exit_xfs_fs);
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1923:1: Anmerkung: Ziel »cleanup_module« wurde hier deklariert
1923 | exit_xfs_fs(void)
CC [M] fs/xfs/xfs_log_cil.o
CC [M] fs/xfs/xfs_buf_item.o
CC [M] fs/xfs/xfs_extfree_item.o
CC [M] fs/xfs/xfs_icreate_item.o
CC [M] fs/xfs/xfs_inode_item.o
CC [M] fs/xfs/xfs_log_recover.o
CC [M] fs/xfs/xfs_trans_ail.o
CC [M] fs/xfs/xfs_trans_buf.o
CC [M] fs/xfs/xfs_trans_extfree.o
CC [M] fs/xfs/xfs_trans_inode.o
CC [M] fs/xfs/xfs_rtalloc.o
CC [M] fs/xfs/xfs_acl.o
CC [M] fs/xfs/xfs_sysctl.o
LD [M] fs/xfs/xfs.o
LD fs/built-in.o
make[1]: *** [Makefile:150: sub-make] Fehler 2
knicko@knicko-Lenovo-ideapad-330-15IKB:/media/knicko/bs-systeme/ni-org/ni-buildsystem$
Hatte bei oe-a auch mal da in die defconfig geschaut, ob sich da was Gravierendes geändert hat, aber da ist nichts, was den Fehler verursachen könnte.
