NI-Image 3.4 - Beta - Changelog
- gandharva
- Box: Tank
Neues Image online
- libstb-hal-cst-next: gstreamer - fix init jump, cleanup
Nazi lives don't matter.
- gandharva
- Box: Tank
Re: NI-Image 3.4 - Beta - Download
Neues Image Online
- armbox: fix gst playback
- partly revert last commit
- gandharva
- Box: Tank
Neues Image Online
- add some openssl symlinks for compatibility
- hd51: add openssl binary to image
- curl: add ca-bundle and link against librtmp
- hd51: use own libstb-hal to ease testing / upstream: https://github.com/TangoCash/libstb-hal-cst-next.git
- libstb-hal: fix uri for http
- update: allow online-update for AX/Mutant \o/
- movieplayer: fix eof-handling for non-coolstream platforms; thx to Satbaby
- locale: minor changes in update-locales
Ab Heute könnt ihr unsere HD51 Images direkt aus Neutrino heraus flashen. Es muss dazu zwingend 1x das aktuellste Image von hier per Hand geflasht werden. Ihr könnt das Image in jede beliebige Bank der HD51 flashen. Danach könnt ihr in Zukunft Online Updates aus Neutrino heraus durchführen.
Für die Sicherung eurer Image Anpassungen könnt ihr nun ebenfalls, wie von den Coolstream Images gewohnt, die backup.sh/tobackup.conf verwenden!
- gandharva
- Box: Tank
Neues Image Online (nur via Neutrino Online Update)
- rework ca-certificate handling for curl/gnutls
libstb-hal:
- rename tSlot -> eDVBCISlot
- modification sendDateTime
- gstreamer: fix get play position
- gstreamer: fix null list
libstb-hal:
- Has thanked: 36 times
- Been thanked: 62 times
Image:
- ofgwrite: allow options to ofgwrite_tgz wrapper script
- ofgwrite: fix osd- and console-messages after flashing
- ofgwrite: fix backup-handling when flashing to another partition
- freetype: 2.8.1
Neutrino:
- channellist: add separator item to menu for a smoother view
- backup.sh: add /var/httpd
- zapit: add missing "case DVB_T2" to getDelSys()
- update: allow ofgwrite to flash another partition
libstb-hal:
Image:
- freetype: 2.8.1
Neutrino:
libstb-hal:
- gandharva
- Box: Tank
Image:
- freetype: 2.8.1
- plugins: coolithek was renamed to neutrino-mediathek; use new github-repo
- emmrd: re-add flag-check for stop-call
Neutrino:
- update_menue: hide expert functions for ARM_HARDWARE
- update: ask for copy settings to new image
- rcinput: add some new keys
- audioplayer: allow RC_previoussong and RC_nextsong
- movieplayer: allow RC_previoussong and RC_nextsong
- pictureviewer: allow RC_previoussong and RC_nextsong
- rcinput: add KEY_PROGRAM
- Revert "- movieplayer: fix eof-handling for non-coolstream platforms"
libstb-hal:
- armbox: add video/audio pid
- armbox: fix audio playback
- armbox: fix audio playback #2
- fix coverart
Image:
- freetype: 2.8.1
Neutrino:
libstb-hal:
- fix coverart
- gandharva
- Box: Tank
Image:
Neutrino:
libstb-hal:
Image:
f325bed - switch all hardware to ni/mp/tuxbox branch
e15c375 - crosstool.mk: force rebuild of static libs after rebuilding crosstool
8756749 - skel-root/hd51: use small helper-script to show user's iframes
4a6f65f - showiframe: install new helper-script too
6f31ef3 - patches: align xupnpd-fix-webif-backlinks.diff4cdaedd - cleanup
886200f - hd51: update gcc (linaro-6.3-2017.02) and use custom kernel for crosstool build
4126418 - hd2: update gcc (linaro-6.3-2017.02)
287cb9e - fix gcc6 compile
6d9aaf9 - hd51: cleanup rcSCode: Alles auswählen
0f420744b - fix compile for coolstream hardware (works on HD2)
4a3c4e4d9 - re-add dummy ChangeLog to satisfy automake
3c248e1af - remove incomplete Changelog file
f6692bff5 Revert "remove pinentered script , revert 9dbdfcf5c7e813c67f44b3255881fd0fe344ad4d"
807f0d826 - icons: optimize png images for size
ec10cd64e remove pinentered script , revert 9dbdfcf5c7e813c67f44b3255881fd0fe344ad4d
0e2efeb9a fix blank screen on start (after merge)
e590888ce - yweb: optimize png images for size
ffe260d35 - yweb: install only box specific remote control pictures
3d91cd9e1 - media-menu: disable currently broken audioplayer for ARM_HARDWARE
39440333e remove unused
9ac5258ac src/gui/movieplayer.cpp reEnable YT
8746340a8 src/gui/movieplayer.cpp fix page up/down jump and stop play after merge
c709acabb - fill webradio_usr.xml with some of my favorite streams
be1ba2c39 - zapit: save last channel for webradio too
ec3400f37 - infoviewer: fix timeout for new mode_webradio
e10515583 - try to fix tv <-> radio switch
49815052f - zapit: don't save webradio-channels as last tv channel
6eea11af9 - movieplayer: fix for 6ce6fd0222648b0111e30a512ad88292e92c8a12
ee8627a84 - movieplayer: rename isWebTV => isWebChannel
cd5577e8b - rename LIST_MODE_WEBTV => LIST_MODE_WEB
b86a3a1a7 - scanepg: rename webtv => webchan
ebcd15da4 - rename IS_WEBTV => IS_WEBCHAN
1a304cede - movieplayer: fix new mode
4ad5798e4 - fix mode in SetChannelMode()
fe487f397 - fix -Wlogical-op errors
a8b0fee59 - add webradio; first steps
ee3599ea6 - fix another merge error vol.2
59a9cc5df - fix another merge error
c1cea39c1 - fix last merge #2
be97dd6bb - fix last merge
83655f78d update version to 3.6.1
7c9bf1df9 menue.cpp: dont use one-time init of a variable that could be changed on runtime
91fdb1ef6 - rename can_set_display_brightness => display_can_set_brightness
674ba19c0 - vfd-setup: use new display_can_deepstandby member from libstb-hal
b76c21381 - simple_display: fix c/p error
10592800e - simple_display: fix some compiler warnings
0fac12001 - simple_display: more readability in togglePower() function
dbce194f8 - simple_display: fix showRCLock() function
61a31e260 - epgview: disable epgid debug code
14861ec92 - simple_display: fix text while rc is locked
ad757a9a6 - movieplayer: add progress to vfd
422a9b41d - introduce simple_display.h; just a cleaned copy of lcdd.h
0b3f91a4c - CMovieBrowser::info_hdd_level(): fix miscalculation
b9c2aaf3a fix hevc record
29221aaca add support for H265
e1349234f - acinclude: move default PUBLIC_HTTPDDIR from /var/httpd to /var/tuxbox/httpd
5ec2e9c11 - audioplayer: allow RC_previoussong and RC_nextsong
73738c344 - simple_display: re-add accidently removed lines ...
d8c0a6af0 - simple_display: fix display of volume in menu- and audio-mode ...
bd013f86b - simple_display: fix brightness settings when changing mode
34f966d22 - simple_display: more readability; just code cosmetics
28fbb16cf - movieplayer: align some variables names to tango's names
0283b4d2d - neutrino: avoid double setMuted() call; already done by g_audioMute->AudioMute()
266062973 - neutrino: don't show volume on startup and on resume
c4e17ca00 - simple_display: unify and clearify console output
edd88db0f - rcinput: add some new keys ...
4a5adfcb2 - update: ask for copy settings to new image
68d8319d2 - update_menue: hide expert functions for ARM_HARDWARECode: Alles auswählen
464838f align
6ae9c7d - rename can_set_display_brightness => display_can_set_brightness
fbd3736 - add display_can_deepstandby member
88ce7b7 gstreamer: reset pids at start
ca49904 gstreamer playback - get real apid from TS
a725528 armbox: fullscreen osd ;)
5ef8f2e gstreamer: fix lang detection
f6ecb88 libdvbci: log cosmetic
564e40b armbox: fix get blank
b443fa0 fixup gstreamer tags
d908c7a armbox: gstreamer tags support
5509c8c fix coverart
cf81628 armbox: fix audio playback #2
f9e91b6 armbox: fix audio playbackNazi lives don't matter.
- gandharva
- Box: Tank
Neues Image Online
Image:
Neutrino:
libstb-hal:
Image:
75da0ba - update inadyn and companion libs
5cda98d - update nfs-utils and companion libs/tools
8cc138c - drop bc
4ab4b59 - update several libs/tools
93d5460 - bootstrap: install libcoolstream based upon NI_FFMPEG_BRANCH variable
2db5f76 - environment: allow to define NI_FFMPEG_BRANCH in config.local
7b5203f - environment: remove 3.x prefix from cst drivers directories
b4301af - ni/mp/tuxbox branch is default now
0c19480 - HD2: update to kernel 3.10.108
62e75ed - skel-root/hd2: copy webradio_usr.xml to var-partitionCode: Alles auswählen
9561a5ecb - capmt.cpp: cleanup
d41235ac3 - port CI handling (thx FlatTV!)
d084f24e5 - infoviewer_bb: fix wrong mode-logic for radiotext icon
987fbf57f - shorten string
eab426f08 - movieplayer: fix screenshot function
361be7bd4 - screenshot: cleanup from many many unused code; ...
bc0de5872 - cleanup from unsupported DUCKBOX_HARDWARE
38c86eed6 - streaminfo2: cleanup from unsupported hardware ifdefs
3f19ddc93 - vfd: cleanup from unsupported hardware ifdefs; vfd.cpp/h is only used by COOL_HARDWARE
81c689280 - movieplayer: re-add missing endif
31fa56f28 - movieplayer: cleanup from unsupported hardware ifdefs
c759d75e8 - re-add working streaminfo for coolstream hardware; ...
86e7ad4ec src/gui/movieplayer.cpp fix break record after play on cst (after hd51 merge)
91a033dfb - infoviewer: fix FIXME comment in 9b340752244980a59d57d3d318f70339a7f8d2e1
472cc578f src/zapit/src/capmt.cpp dont stop decoding if record stops, this break overlapped record on cst
c3292a491 - movieplayer: don't stop playback with RC_home; it's confusing
57f3f6ea4 - neutrino: don't add web-channels to sat-bouquet
ff04c8ce9 - streaminfo: fix compile for coolstream; add dummies to libcs-headers
4a4548379 - streaminfo: some more position fixes; ...
da57a16a8 - streaminfo: add channelname for webtv/radio too; simplify code
fc12241af - streaminfo: re-add osd resolution
219ead7e3 - locale: minor changes in streaminfo locales
20ad20b57 - streaminfo: use OFFSET defines; some position fixes
63cd2d48d - streaminfo: minor re-formatations and whitespace cleanups
4963a6a77 - streaminfo: show channellogo in mode-webradio too
d3b4fae12 - streaminfo: port from TangoCash
5f680879f - infoviewer_bb: minor change in icon handling
02aefef16 src/gui/movieplayer.cpp fix audioselect in not filpeplayer mode (after merge)
8d9bce4cd - streaminfo: fix resolution for webradio; ...
11eac4a84 - streaminfo: fix merge error
5bbbfe3ec - streaminfo: some mode_webradio fixes
5b6d3ea78 - neutrino: some more mode_radio/mode_webradio fixes #2
b025f8abb - neutrino: some more mode_radio/mode_webradio fixes
002ef3a1c menue.cpp: add reverse search to find selectable item
f855209de CImageInfo: fix version string format
f736dfa25 - neutrino: respect user's infoviewer timeout settings for different modes
fd17bd9c5 disable file player mode for cst
9b3407522 - infoviewer: try to get meta data from stream when epg is empty
7c7dcec0a - infoviewer_bb: fix display of icons in radio/webradio mode
eae97a31f - movieplayer: add some console spam to check modes
58db5ee33 simple_display.cpp: partial revert "fix generic build"
c56753c8e - infoviewer: try to fix showLivestreamInfo() for audiostreams
c5be130ba - movieplayer: try to fix rezap audiostreams
42e507005 - tuxtxt: change some default values
d90d34e5d - tuxtxt: fix compiler warnings; simplify ifdef's
5a0abfafd - tuxtxt: align to mp
2a2aadb30 fix generic keyboard
75fd96f6b silence -Wparentheses-equality warning
c7c52324a fix generic build
e612dae6b - configure.ac: align package name
d7f1984ab - autogen.sh: align package name
51b798032 - acinclude: fix indentationCode: Alles auswählen
0d8ae30 gstreamer playback: remove subtitles until fully supported
b4dfa39 gstreamer playback: fix possible segfaults
17f98cc CI: fix some caid issues (thx dboxoldie)
a513b0b ci: armbox fix cpu load
cdbe044 fix compile #2
b5820fa fix compile
8886015 armbox: add dvbci (thx DboxOldie)
dfeace5 armbox: tryfix cec
71c9c9d ci: let stbhal handle close
97f7c23 gstreamer playback, cleanup, fix real pid handling
28aa514 gstreamer playback, avoid segfault
cccd010 gstreamer playback, fix possible segfault #2
161feb4 gstreamer playback, fix possible segfault
8218368 update generic gstreamerNazi lives don't matter.
Neues Image Online
Image:
Neutrino:
libstb-hal:
Image:
7d6aa46 - glib-networking: bump version to 2.54.1
c55b4a3 - alsa-lib: bump version to 1.1.5
3246dd2 - mc: bump version to 4.8.20
b672843 - start-neutrino: get sure we don't have the /tmp/.timer file when rebooting
e3c95cb Fix libfribidi download url
7407396 - skel-root/cst: move shutdown_helper call to own init script ...
cd1328c - skel-root: rework neutrino start script; align to new exit codes
740f968 - skel-root/hd51: show usb icon in frontdisplay
ddd3a91 - skel-root/hd51: show hdd icon in frontdisplay
c371a32 - skel-root/hd51: load modules as early as possible
323fa6d - ffmpeg: add --enable-demuxer=image2 switch for hd51
fb2511b - ffmpeg: re-add mpjpeg demuxer
b9b800c - HD51: switch to boxmode 12 (needs testing)
56ad0e0 - drop flash-image-arm-single
56cf742 - fix typo
f7b6080 - rename libglib to libglib2
5eb901b - rootfs.mk: create /home directory for hd51
dd7afd9 - add new target 'make init-scripts' to avoid duplicates in skel-root
1751a00 - infoviewer_bb: fix offset for first status-icon
866a2c3 - infoviewer_bb: use OFFSET defines; ...
2e4b002 - infoviewer_bb: take footer height from CComponentsFooter ...
79bad6b - zapit/frontend: fix compiler warning
6f1a763 frontend: fix fall through
e4bdd47 add DVB-T2 support, enable 5V supply
ff4a17e prepare for T2 patch
5e7472e - usermenu: cleanup from ITEM_RASS
79fcd21 - infoviewer: rework radiotext element; ...
edee40e fix AAC record and playback
e6e27d2 - zapit: remove some ifdef's; prepare for upcoming patches
37028e5 - neutrino: don't write timerinfo's when exiting to reboot
25c8220 - neutrino: re-disable screensaver for mode_webradio on ARM_HARDWARE
81b8266 - screensaver: move more repeatedly used code to screensaver's code
c963587 - movieplayer: use members from screensaver's code
74bc2e8 - neutrino: move screensaver members to screensaver's code
962bcae - neutrino: enable screensaver for mode_webradio
c5b6543 - shutdown_helper: better explanation of what the tool does; ...
e8bb447 - radiotext: cleanup from tons of unused code; rass is dead
1c638ba - icons: cleanup from unused icons
811fcbe - icons.h: cleanup from unused defines
52b0f6c - remove unused src/driver/stacktrace.h; use src/system/stacktrace.h if needed
a063b37 - neutrino: try to fix timer_wakeup handling; ...
090fcd4 - locale: minor changes on new tunersetup locales
241ea9d de-saturize color buttons a bit
60ff2da restore start and shutdown pictures after merge
8cefe9a - cablex.xml: add OstTelCom; thx to elstablo
66979ea - mediaplayer: disable fileplayback audio for coolstream; that doesn't work
9b53d11 - webtv-setup: clearify hint for autoload item
3d6eb97 - webtv-setup: just fix indentation
c42b86e fix radiotext for armbox
c64b184 - movieplayer: just fix indentation
d2d1cbc Revert "shutdown_helper: add calling '/etc/init.d/rcK'"
069774f - controlapi: fix typo in 110588d39b2ff55630af60845e8c01c7d665d9dc
377db42 - flash.start: minor changes in script comments
c88120c fix webtv script path
caface0 CComponentsTimer: try to fix timing on non cst hardware
a857be6 - neutrino: deactivate compatibility code in ExitRun(); ...
d6bba3e - neutrino: add exit codes to handle some actions in neutrino's start script
f67ddda - neutrino: always write /tmp/.timer ...
14fafa3 - neutrino: unify console-output for different conditions in ExitRun()
3f60582 - neutrino: fix file-check in ExitRun() ... was a c/p error
6709ae0 shutdown_helper: add calling '/etc/init.d/rcK'
490d46e - rename uncooloff workaround to something less idiotic
c95d511 - neutrino: more small cleanups in ExitRun()
f128d38 - neutrino: cleanup ExitRun() function from unused code
fe35b42 - controlapi: add mode_webradio to GetModeCGI()
9645cb2 - neutrino: clearify mode handling in saveEpg() function
0fc3e79 - neutrino: unify modes handling; ...
1f86b6a capmt.cpp: Fix stop decoding
9109891 - simple_display: show scrambled icon on scrambled channels
ec7403c - simple_display: show mute icon in muted mode
94517d3 src/gui/components/cc_frm_window.cpp: fix too small left bottom corner
8613e5d CTestMenu: add gui restart item for faster access
60bf6d7 CImageInfo: expand fallback to get readable version string
6911ffe - neutrino: fix tv/radio switch for coolstream; ...
541edc7 add dependency to libswscale for armbox
bed92ab - capmt: revert minor changes from last merge
8acb4a4 - neutrino: don't load webradio xml on HD1 hardware; ...
549194b - simple_display: fix compile for GENERIC_HARDWARE
64a2c1e armbox: read frontend real names
dbf2fa3 - vfd-setup: allow to set scroll_repeats if possible
bf88e29 - neutrino: display's setScrollMode() needs to be called on every start
2927201 - simple_display: dont show symbols in shutdown mode too
a622671 - vfd: re-add by mistake removed setting "off" for statusbar
742d2c6 - timerlist: don't cast saved_displaymode
3c6711d - movieplayer: try to fix display of servicename; ...
463c4ec - simple_display: simplify some proc_put calls
5a5a5e7 - proc_tools: add helper member to put values w/o length; ...
a798075 - simple_display: switch back to simplified proc_put calls
d7fd8cc - proc_tools: c => cpp; add new helper member to write bool values
82a6af6 - simple_display: align f9b55ca to new proc_put calls
37f50b5 hd51: dont show symbols in standby
e2c6689 - simple_display: allow to set scroll mode
e90fe75 - simple_display: use proc_tools
456c12d - neutrino: avoid some ifdef's; prioritize proc filesystem
98e4d45 - system: add seife's proc_tools
bc43a76 capmt.cpp: try to fix ci handling
60d6fd6 - vfd-setup: hide statusline option from models w/o a statusline in vfd
1198764 coolstream/hardware_caps.h: fix broken cs build
705ba72 - hardware_caps: add display_has_statusline member
48e0d85 - vfd-setup: more readability; just cosmetics
1e0ef81 - vfd-setup: don't show separatorline when backlight menu isn't shown
a0a76fe - simple_display: avoid compiler warning
f7c0cd6 - simple_display: fix compile for non-ARM_HARDWARE
833aed0 - simple_display: add possibility to show text when changing mode
72514fd - simple_display: add missing MODE_MENU_UTF8 check in setMode()
2cb111f - simple_display: rename display() to ShowText() ... as in vfd.cpp
1309d5a - simple_display: cleanup from unused code inside ifdef mess
06aebf6 - timerlist: fix saved_dispmode
01a0401 - cables.xml: use german umlauts for german nets; ...
dbf3cb8 - update: fix display of installed version; ...
953793f - infoviewer: fix radiotext icon for webradio
dc78eaf - neutrino: fix console output to signalize timer wakeups
a0c96ca - capmt.cpp: cleanup
1ba4533 - infoviewer_bb: fix wrong mode-logic for radiotext icon
9c041c5 - shorten string
cf19085 - movieplayer: fix screenshot function
1a58294 - screenshot: cleanup from many many unused code; ...
514bd93 - cleanup from unsupported DUCKBOX_HARDWARE
c154364 - streaminfo2: cleanup from unsupported hardware ifdefs
62843ec - vfd: cleanup from unsupported hardware ifdefs; vfd.cpp/h is only used by COOL_HARDWARE
868f618 - movieplayer: cleanup from unsupported hardware ifdefs
d5be64f - re-add working streaminfo for coolstream hardware; ...
e2770e7 - infoviewer: fix FIXME comment in 9b340752244980a59d57d3d318f70339a7f8d2e1
4e87634 - movieplayer: don't stop playback with RC_home; it's confusing
5bc21a6 - neutrino: don't add web-channels to sat-bouquet
e411a77 - streaminfo: fix compile for coolstream; add dummies to libcs-headers
b526dbf - streaminfo: some more position fixes; ...
d3d0204 - streaminfo: add channelname for webtv/radio too; simplify code
f033e62 - streaminfo: re-add osd resolution
29580c7 - locale: minor changes in streaminfo locales
280df53 - streaminfo: use OFFSET defines; some position fixes
4ba276f - streaminfo: minor re-formatations and whitespace cleanups
34acd9b - streaminfo: show channellogo in mode-webradio too
ffb15f0 - streaminfo: port from TangoCash
470460e - streaminfo: fix resolution for webradio; ...
dc84e80 - streaminfo: some mode_webradio fixes
4202218 - neutrino: some more mode_radio/mode_webradio fixes #2
d843316 - neutrino: some more mode_radio/mode_webradio fixes
942c641 - neutrino: respect user's infoviewer timeout settings for different modes
e31eec2 - infoviewer: try to get meta data from stream when epg is empty
6b470be - infoviewer_bb: fix display of icons in radio/webradio mode
6f1b9d6 - movieplayer: add some console spam to check modes
ab39aa5 - infoviewer: try to fix showLivestreamInfo() for audiostreams
c82ba48 - yweb: optimize png images for size
0cfa8b8 - yweb: install only box specific remote control pictures
61ff980 - media-menu: disable currently broken audioplayer for ARM_HARDWARE
6717501 - fill webradio_usr.xml with some of my favorite streams
c0e1a66 - zapit: save last channel for webradio too
14c2a27 - infoviewer: fix timeout for new mode_webradio
6259467 - try to fix tv <-> radio switch
522477b - zapit: don't save webradio-channels as last tv channel
1a86d7d - movieplayer: fix for '- movieplayer: fix new mode'
a6e00fb - movieplayer: rename isWebTV => isWebChannel
0b78ac9 - rename LIST_MODE_WEBTV => LIST_MODE_WEB
3946379 - scanepg: rename webtv => webchan
740fd3a - rename IS_WEBTV => IS_WEBCHAN
098f021 - movieplayer: fix new mode
8d3f2ce - fix mode in SetChannelMode()
a65a639 - fix -Wlogical-op errors
3fd5447 - add webradio; first steps
9bf563c - tuxtxt: change some default values
abc2e90 - tuxtxt: fix compiler warnings; simplify ifdef's
e607bae - tuxtxt: align to mp
1b39396 fix generic keyboard
555f185 - fix compile for coolstream hardware (works on HD2)
90f5418 - acinclude: fix indentation
1de277e CServiceManager: add member GetCurrentChannel()
7370c4c widget/menue_target.h: add possible required includes
f6253de - neutrino: add "need_reboot" feature
ca9639b - infoviewer_bb: minor change in icon handling
c4a5937 hd51: fix wakeup from standby
06036f2 - hardware_caps: fix compile for coolstream; add missing member to header
54c5d19 fix audio description after play movie
f3775d1 capmt.cpp: change CI handling for testing
61e2beb - re-remove unneeded ifdefs
0a0d57c - remotecontrol: resolv commented merge conflict
f3ded5d - some minor renamings
f5e07c5 fix max apids
188f10d disable test
3ac8fa2 write m2v direct to device
8a3ba60 align gststreamer findallpids to eplayers logic
6af94cc porting av converter to sh4
d18ff77 fix possible memleak
6af1864 convert pix fmt
6b9e790 fix logic and possible memleak
cefff90 fix last commit
fd512df check alloc AVFormatContext
d55f592 fix close fp
92646d5 convert jpg to m2v with libavcodec, need --enable-demuxer=image2
d016c73 cleanup
cde1e65 fix 0648 caid issue (dbo!!!)
3c12a78 try to fix possible race condition
617ecb7 - truncate incomplete changelog
32a72a7 sync with oher repo
0b9575f fix merge error
921f1b6 - generic-pc: remove double key definitions
ceb1620 remove double keys
70cdad0 - add display_has_statusline member
6c0d55d - generic-pc: add our proven keymap to glfb
f7a69a6 align to changes
0f958a7 init mpegts
88d4c16 Revert "return false in decoder have no time"
f9daec2 move gchar * sourceName = gst_object_get_name(source);
745959a fix last commit, broken check logic
93fc10c check if tag is gst list
7257954 return false in decoder have no time
4846492 try to fix freeze with subtitle file , use gst_element_get_state only if need
bc4a9b3 fix missing close fd (thx dbo)
10b2aaa check m_stream_tags if not NULL
0034be6 add check if children not NULL
f89bffb fix memleak, init and compil
1e8e9bc gstreamer playback: fix possible race condition
54341f0 gstreamer playback: fix possible segfault
Neues Image Online
Image:
Neutrino:
libstb-hal:
Image:
nix ^^
e831b2e fix bouquets freq handling for DVB-T/T2
ee155ad - acinclude/configure: some more minor format changes
a43454f - acinclude/configure: some minor format changes; fix indentations
62f54dc - configure: fix logic around libswresample
03d551d - configure: move libstb-hal block down
f66f381 - acinclude: use AS_HELP_STRING() for --with-boxmodel; ...
c36039b - configure: invert --disable-lua false logic to --enable-lua true
01414d7 - configure: invert --disable-upnp false logic to --enable-upnp true
9317e78 - acinclude: unify descriptions in TUXBOX_APPS_DIRECTORY_ONE()
a1e1621 - configure: unify and simplify some AC_ARG_ENABLE() calls
4085966 - acinclude: minor format changes in --enable-reschange code
8084c1d - acinclude/configure: show defaults
ab8d53a - acinclude: replace custom formatting in TUXBOX_APPS_DIRECTORY_ONE with AS_HELP_STRING()
7c9ff58 - configure: cleanup from commented code
f4b775b - acinclude/configure: unify usage of AS_HELP_STRING(); minor format changes
bcaac2a - acinclude: small resort to get the plugin-dir variables consecutively
b4fc53b - acinclude: remove some double code
a88019d - autorun.sh: align to neutrino's exit codes
29cce3f fix cable nit
1f1b85a - neutrino: fix service restart item in usermenu
5955e2b osd_setup.cpp: fix colormenu shadow
c581221 - zapit/scannit: fix typo in last commit
434a9b9 fix scannit
67b8037 update scan infos
5a6df22 show PLI/PLC/PLM while scanning
15e49f9 add PLI/PLC/PLM to manual transponder selection
7b47ab4 workaround for T2 resolution display
4e65f22 add DVB-S2X support
8ba4a58 fix DVB-T2 transponders
f3283ed fix frontend Uni2 / JESS (thx DboxOldie)
3c859db localize: try to fix different path to iso tab
114cd36 yWeb Help: remove invalid help links
882a465 widget/hintbox.cpp: add explicit init of var picon
e9883cb cc_item_picture.h: remove virtual declaration from setPicture()
5ff88f5 - neutrino.h: remove obsolete external genre_sub_classes variables
30c0a32 fix radiotext title background (merge fix)
09858af enable yt for generic
a6a2561 typo
1f96c8a fix resource leak
77db4a6 - infoviewer_bb: use OFFSET defines; ...
0fb41ee - lcd4l: detect radiotext (/tmp/lcd/radiotext)
433b398 - lcd4l: accept NeutrinoModes::mode_webradio too
e17aeb4 - lcd4l: use global Neutrinomodes instead of own enum
090120f Revert "- media-menu: disable currently broken audioplayer for ARM_HARDWARE"
a179a38 - ffmpegdec: fix audio playback for ARM_HARDWARE
aca5157 - infoviewer: avoid display of radiotext icon in virtual zap mode
38e76f6 - infoviewer: cleanup from some unused code
52b0aaa fix possible segfault
64b58eb armbox: fix write value hex
