Wise Duplicate Finder Pro 1.2.8
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Wise Duplicate Finder Pro 1.2.8
Wise Duplicate Finder Pro is a duplicate file management tool that can help you find and delete duplicate files by comparing file name, file size or contents. We download a lot of documents, photos, songs and movies in our daily life. As time goes on, they will fill up your hard drive. You find yourself frequently running out of disk space. Wise Duplicate Finder can help you locate and remove unnecessary duplicates, free up your disk space.
Manage Any Type of Duplicates;
Find Empty Files;
Delete Duplicate Copies Manually or Automatically;
Backup and Restore.
Link
mfG
Trapped
Kein Support per PN/Mail
