Easy Audio Mixer 2.3.1 & MZ Folder Print 1.0.0
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Easy Audio Mixer 2.3.1
Easy Audio Mixer ist ein Multitrack-Editor für alle! Damit erstellt ihr in Sekundenschnelle eigene Audioprojekte - auch ohne Vorerfahrung! Ob Präsentationen, Podcasts oder sogar Musik - diese Software bietet euch alle nötigen Tools!
Link
Giveaway of the day — MZ Folder Print 1.0.0
MZ FolderPrint is a lightweight Windows application designed to help users view the space occupied by each file on the disk. It boasts a clean and straightforward layout that allows you to select the folder or drive to be scanned. The application gives you the possibility to include sub folders in the searching process, show the size of the items or display only the files found in the specified directory, as well as select from three different viewing styles (text, list, or grid).
One of the top features bundled into MZ Folder Print is a smart filtering system which allows you to search for items with a size less or more that a user-defined value.
MZ Folder Print carries out the searching process extremely quickly and without errors throughout the entire process. It doesn’t eat up a lot of CPU and memory, so the overall performance of the computer is not hampered.
NB: To activate the software follow the instruction in the Readme. The key may take some time to come! The software can be activated after the Giveaway is over
Link
mfG
Trapped
Kein Support per PN/Mail
