CST Release Image Nevis (HD1, BSE, NEO, NEO², ZEE)
Gesperrt
Has thanked: 61 times
Been thanked: 100 times
Hier die Release 2.14 von CST für Nevis (HD1, BSE, NEO, NEO², ZEE): http://neutrino-images.de/storage/publi ... is-214.img
Changelog:
Software Update Wizard - Agreement
Do not perform updates using any data other than the official update data from our website.
Using software updates you expressly acknowledge and agree that use of this Software is at your own risk.
In no event Coolstream LTD shall be liable for any damages whatever.
Contact info@coolstreamtech.com for any questions about our software.
V2.14 UPDATE(10.06.2014) HD1, NEO1, ZEE, NEO2
Warning:
This release will upgrade your Kernel on first boot if not already done!!!
Please dont power off your receiver bevore upgrade is done!
* 2.14 update (LUA fixed)
* HDD: format to more filesystem supported
* HDD: added device mount/umount
* UPNP: radio channels now can be shared with xupnpd
* add opkg manage menu (to use, add your /var/etc/opkg/opkg.conf)
* option to start box always with configured volume level
* EPG scan: options to scan in live/standby mode
* EPG scan: possible to selected favorites bouquets to scan
* add support to stream channels from different tuners
* add delete whole satellite channels from channel-list menu
* split direct record and timeshift max time to record options
* support different PIP size/position setup for tv and radio modes
* file play fixes and improvements
* add option to configure subtitles font size for file playback
* other fixes and improvements
Gesperrt
Zurück zu „CST-Images“
