oMega Commander 2.3.14
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — oMega Commander 2.3.14
oMega Commander is a modern file manager that bundles a wide set of both basic and advanced file and folder managing functions with quick access to Operation System applications, controls and popular internet resources.
Everything is intuitive and highly customizable. The classical split-panel layout is enriched with a number of visual innovations. Learning the new features and customization is easy thanks to animated tooltips and pointers, search-enabled Settings dialog, detailed embedded and online help system. File operations have been optimized for speed and accompanied with performance details. Viewing and editing of many file types can be done right inside the Commander.
The ultimate goal of oMega Commander is for it to be your main control room of your personal computer, and to help you be more focused and productive with your own great projects.
Link
mfG
Trapped
Kein Support per PN/Mail
