PDF Merge Pro 2.0.1 & Video Enhancer 2.1.2 & Scepter of Ra
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — PDF Merge Pro 2.0.1
People, especially office staff, always find it difficult to merge two or more PDF documents into one. Wonderfulshare PDF Merger Pro is a quite useful PDF application which will help you to merge multiple PDF documents into one master PDF doc. It is clean, fast and stable . You can merge your multiple PDF documents in no time.
Link
Giveaway of the day — Video Enhancer 2.1.2
Video Enhancer is a tool for increasing resolution of videos: from SD to HD, from HD to 4K, or any other size. It's based on Infognition's Super Resolution technology that uses motion search and intelligent frame fusion to combine information from several neighboring source frames into each output frame. By using more information than there is in one single frame, this multi-frame motion-based method can deliver more details than any ordinary video resizing algorithms.
In addition Video Enhancer supports more than 200 plugins for all kinds of video processing: brightness and contrast correction, color correction, denoising, deinterlacing, sharpening, overlaying and removing subtitles, different video effects like turning video into cartoons or making it look like old film and others. A few most popular plugins are included by default, others can be automatically downloaded and installed with one click from their list with descriptions inside Video Enhancer.
Video Enhancer can read most video formats and use any DirectShow or Video-for-Windows codec you have in your system. It outputs AVI and MP4 files. Batch mode is available for processing multiple files in a row, as well as command-line interface for external automation.
Link
Game Giveaway of the day — Scepter of Ra
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
Puzzle your way through 150 perplexing levels in Ancient Egypt! In Scepter of Ra the aim is simple: fill the board by pushing the stones onto the playing field. As soon as a group of three or more stones of the same color are linked together you score points. Take on the challenge of the pharaohs and connect the hieroglyphic stones to reveal the amazing Golden Pyramid!
3 unique game modes;
150 game levels;
Fantastic bonuses.
Link
mfG
Trapped
Kein Support per PN/Mail
