ParkControl Pro 1.2.5.6
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — ParkControl Pro 1.2.5.6
ParkControl Pro is a unique application that will let you take control of your CPU core parking (hidden in power options by default) and frequency scaling in an easy to use interface. It also has a real-time display of cores parked, and a system tray icon that changes dynamically when cores are parked. Best of all, it includes our Bitsum Highest Performance power plan and 'Dynamic Boost', which can boost your PC to its best performance while you are using it, but then lower down to something more conservative when you are not.
Note: the program archive includes both x32 and x 64 installers!
Link
mfG
Trapped
Kein Support per PN/Mail
