4Videosoft Video Converter 6.0 & Dr Folder 2.1.5
Keine Stimmen
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — 4Videosoft Video Converter 6.0
4Videosoft Video Converter is the most professional multifunctional total video converter, which supports all video and audio formats, including SD, HD, and 4K UHD videos. It converts videos to other video and audio formats (MP4, M4V, WMV, MOV, AVI, MKV, FLV, MP3, WMA, etc.) for playing on portable players (iPhone SE, iPhone 6 Plus/6s Plus, iPhone 6/6s/5/5s/5c/4S/3GS, iPad Pro/Air, iPod touch, iPad Mini, iPad Mini 2, iRiver, PSP) and other portable devices.
This program gives a new enhancing function for you to improve video quality. It provides you with a clear and clean screen by upscaling resolution and removing video noise. Also, it can clip/merge/rotate/turn to 3d/watermark/edit video and audio effects for your pleasure.
4Videosoft provides a 50% off coupon code: VIDEGOTD (apply to recommended products and other products) for all GOTD users.
Link
Giveaway of the day — Dr Folder 2.1.5
Dr. Folder is a software that searches and replaces a standard icon of a folder to any other icon. It is a powerful, easy to use software with pretty and friendly interface. You can change folder icons quickly and freely just by clicking several buttons. So, using Dr. Folder can save you lots of time. The most important feature is that it can make your folders lively and make others envy!
Link
mfG
Trapped
Kein Support per PN/Mail
