WonderFox DVD Ripper Pro 12 & Icecream Image Resizer Pro 2.08
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — WonderFox DVD Ripper Pro 12
This is a real No. 1 speed DVD conversion and backup tool that provides the quickest solution to convert and back up DVD to a wide range of media formats.
Designed to simplify your life, the program provides you with the best solution to back up your DVD collections. You can convert the disc into digital for personal use to watch your favorite movies on your PC, iPhone, iPad, Tablet and any more.
Moreover, it adds optimized presets for devices such as the latest iPhone XS, iPhone XR, All New iPad Pro, Samsung Galaxy S9, Note 9, LG V40, etc. And it's a zero-difficulty tool, with only (Load DVD > Output Format > Get Started) three steps to finish the work. Blazing fast ripping speed, but preserves high original quality.
New Features:
Supports hardware encoding (Inter QSV, Nvidia NVENC). Up to 30X faster conversion speed than the previous version.
Supports up to 8k (7680*4320) resolution, and forced subtitles.
Improves the stability of HEVC(H265).
WonderFox DVD Ripper Pro Lifetime (1 PC). It's only $24.95 to buy. (Regular price: $39.95)
WonderFox DVD Ripper Pro+HD Video Converter Factory Pro Pack. It's only $29.95 to buy. (Regular price: $69.95)
WonderFox DVD Ripper Pro Family Pack (3 PCs). It's only $59.95 to buy. (Regular price: $89.95)
Link
Giveaway of the day — Icecream Image Resizer Pro 2.08
Icecream Image Resizer is an extremely simple to use software to change the size of the images. The program supports such image formats as JPEG, JPG, GIF, PNG, BMP, TIFF and TIF. The images can be perfectly resized in a bulk. Files can be dragged and dropped into the program's window, added one by one (the “Add image” button) or by folders (the “Add folder” button). There are multiple various resizing presets to choose from (the “Profile” option). Apply the “Vertical images recognition” option to switch width and height values of the added vertically oriented images before the resizing process. Add custom watermark for the resized images and its opacity if needed.
Link
mfG
Trapped
Kein Support per PN/Mail
