MSTech Folder Icon Pro 2.9.3 & LightMV VIP
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — MSTech Folder Icon Pro 2.9.3
MSTech Folder Icon is an efficient and user-friendly piece of software developed to offer you the means of customizing the looks of your directories' icons, enabling you to work with a wide array of images and colors.It gives you everything you need to create unlimited amazing folder icons and assign them to any folder, in the easiest way possible.In fact, it is a real Folder Icon Factory, gives you various type of options that make you able to create unlimited folder icons and use suitable icons for your windows folders.
Why MSTech Folder Icon Pro?
Why it is the Number One and The Best "folder icon software"?
What are the advantages?
- Ability to have 5 favorites icon packs, in the right-click menu
- Ability to create your desired folder icon, from any image sources
- Ability to Create unlimited icon packs, from any sources
- You can download and use amazing free icon packs from the website.
and ...
It is an attractive and appealing utility, whose aim is to assist you in personalizing, categorizing and organizing your system's directory icons, by assigning them better suited fantastic folder icons and making them easier to distinguish.
Furthermore
You won't need to pay additional costs for professional icon packs anymore, MSTech has surprises and gifts with amazing free icon packs for you. MSTech graphic team designs and release amazing ready icon packs, and you can download them from our website, add them to the software library and use them free of charges.
SPECIAL OFFER FOR GOTD:
Buy MSTech Folder Icon Pro v2.9.9.960 + FREE UPGRADE to v3.0 + FOR 2PCs - 55% OFF ($20). One Day Only.
Link
Giveaway of the day — LightMV VIP
LightMV ist ein webbasiertes Videotool, mit dem ihr eure einfachen Fotos in ein beeindruckendes Video mit hoher Qualität verwandeln könnt. Es gibt verschiedene Vorlagen für verschiedene ereignisreiche Situationen, z. B. Hochzeit, Geburtstag, Zeremonie, Abschluss, Urlaub, Reisen, Geschäftsangelegenheiten und vieles mehr. Nur in wenigen Minuten kann man ein professionelles Video erstellen.
Einfache Schritte zum Erstellen eurer Videos:
1. Vorschau sehen und die gewünschte Vorlage auswählen.
2. Fotos oder Videos hochladen.
3. Bearbeiten von Fotos oder Videos mit allen integrierten Funktionen.
4. Bearbeiten von Texten.
5. (Optional) Ändern der Standardhintergrundmusik.
6. Klicken auf "Produzieren", um euer Projekt zu bearbeiten und anschließend herunterzuladen.
Hauptmerkmale von LightMV:
• Webbasierter Dienst, es müssen keine Desktop-Programme installiert werden.
• Videos werden in hoher Qualität ausgeben (HD 720P).
• Etliche Designvorlagen.
• Bietet einfache Fotobearbeitungswerkzeuge.
• Ermöglicht die Verwendung eurer bevorzugten Musik für das Video anstelle der Standardeinstellung.
• Unterstützt das Hinzufügen von Texten und Titeln nach Belieben.
• Integrierte Email-Alarms, die euch an die erzeugte Datei erinnern.
• Herunterladen von Videos ohne Wasserzeichen.
• Einfaches Teilen in sozialen Netzwerken.
NB: 6-Monate VIP-Konto.
Link
mfG
Trapped
Kein Support per PN/Mail
