Batch Text File Editor Professional 5.0.19 & The Treasures Of Montezuma
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Batch Text File Editor Professional 5.0.19
Replace, insert, delete, copy, and move text in multiple files in bulk!
The program features RegEx support with colored syntax highlighting and RegEx match substitutions. Multi-line replace lets you search for and replace text spanning multiple lines. Wildcards, case sensitivity, and match counting options can refine your search!
Insert new text at specified line number, character position. Delete, copy, and move specified text blocks. Includes complete Unicode and RegEx support. RegEx pattern builder will help you design and test regular expressions right within the program. Specialized RegEx tools like HTML/XML tag selector, line selector, or number selector make it easier to create RegEx patterns. Perform multiple replacements easily by entering search-replace pairs into the grid or import them from a file.
The program has complete Unicode support. Process 1000s of files using multiple CPU cores in manual, automatic/continuous, triggered/scheduled, or console modes, or directly from Windows Explorer right-click menu. Save files to output directory specified using either absolute or relative path, with the original or new name defined by a mask. Select files for processing based on their name, dates, size, and contents using advanced file search supporting RegEx and advanced wildcards. Optionally merge together, split all, or zip processed files. Perform different operations on different files with conditional processing and process branching. Detailed processing logs are available in both user interface and log files. Run multiple program instances simultaneously.
Professional Edition has the following restrictions:
Max File Size is 100MB;
Maximum number of files per batch is 1000;
Scheduling and command line operation is not supported;
Conditional processing is not supported.
Please note: the license is provided for 3 years.
Link
Game Giveaway of the day — The Treasures Of Montezuma
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
In The Treasures of Montezuma, you'll do more than match ancient artifacts and activate powerful magic totems. You'll also follow the beautiful and clever Dr. Emily Jones as she solves a mystery that can transform the world. The beginning of her quest takes her to the mountains of Mexico, where she makes an astounding discovery that sets the archaeological world on fire. But that's only the beginning of the challenges she'll face.
Link
mfG
Trapped
Kein Support per PN/Mail
