Aiseesoft Burnova 1.3.52 & MSTech Cheque Print Basic 1.4.13
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Aiseesoft Burnova 1.3.52
Your 100% reliable assistant for creating DVD/Blu-ray - Burnova. With its own friendly interface and advanced functions, it is not a problem for you to create DVD/Blu-ray, like DVD-R, DVD+R, DVD-RW, DVD+RW, DVD+R DL, DVD-R DL. Burnova supports most formats of videos, like MP4, AVI, WMV, MKV, M4V, MOV, MTS, VOB, etc. And it also can help you add and edit audio track and subtitle, merge and split chapter, select the disc type and aspect ratio and set the quality of videos. By the way, it recently has updated its ISO engine so that it would be more powerful and steady during your creating.
You should have a try to see this magical software.
Aiseesoft provides 50% off coupon code: AISESUOD (apply to recommended products and other products) for all GOTD users.
Link
Giveaway of the day — MSTech Cheque Print Basic 1.4.13
MSTech Cheque Print is not only a cheque printing software, but it's also a comprehensive software which makes you able to manage your bank accounts, payments, and transactions in the easiest way.
It's multi-currency, that means it can be used in any country for any bank. Useful features and quick business reports, such as bank reconciliation, quick detailed voucher printing and archiving, amazing dashboard with quick views and access to the important data such as issued cheques and status list, needed budget for each account including today, tomorrow and next 7 days, cheques waiting for approval, upcoming cheques, interactive calendar, currency converter, and advanced search makes you confident enough to manage your bank accounts and cheque books professionally.
Extraordinary easy to adjust unlimited cheque books, ability to print additional descriptions such as "A/C Payee Only, Not Negotiable...", ability to calculate the cheque date intervals, in batch printing mode, such as on 5th of each month or every 20 days, font and color settings and etc... makes MSTech Cheque Print unique and the best.
SPECIAL OFFER FOR GOTD:
Buy MSTech Cheque Print Pro v1.4.13.1531 + FREE UPGRADE to v2.0 - FOR 2PCs + 80% OFF ($55) Save $215. One DAY ONLY!
Buy MSTech Cheque Print Basic v1.4.13.1531 + FREE UPGRADE to v2.0 - FOR 2PCs + 79% OFF ($35) Save $132. One DAY ONLY!
The Giveaway Promotion Details:
- No Free Update
- No Free Upgrade
- No Free Support
- No Commercial Use
The videos for MZ Cheque Print
Link
mfG
Trapped
Kein Support per PN/Mail
