Driver Easy Pro 5.6.11 & AOMEI Partition Assistant Pro 8.2
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Driver Easy Pro 5.6.11
Driver Easy helps you automatically detect missing or outdated drivers in your Windows computer, download and install the latest version of correct drivers, and resolve your driver issues with just a few clicks! With Driver Easy, you don't need to spend hours searching the correct driver on the Internet, you don't need to risk installing the wrong drivers, and you don't need to worry making mistakes!
Please note: the program includes 6 months license!
Link
Giveaway of the day — AOMEI Partition Assistant Pro 8.2
AOMEI Partition Assistant Pro is a complete, simple, and reliable partition software and disk manager for Windows PCs and laptops. It brings a set of powerful tools to maximize disk space use and improve overall performance of your computer.
Key features:
Change Partition Size: extend, shrink, merge, split partitions, and allocate free space from one partition to another;
Easy Wizards: Extend Partition Wizard, Partition Copy Wizard, Disk Copy Wizard, and Partition Recovery Wizard;
System Migration: migrate your OS from an old HDD to a new SSD or HDD, supporting MBR and GPT disks;
Safe Converters: convert MBR to GPT disk, convert dynamic disk to basic, convert NTFS to FAT32, and convert primary to logical partition;
Windows To Go Creator: build a portable and fully functional Windows 8.1/10 system on a USB flash drive;
Make Bootable Disc: create a Windows PE bootable CD/DVD or USB flash drive without installing Windows AIK;
Create second Ext2/Ext3 partition on SD cards and USB flash drives without formatting;
More features
Please note: the offer includes 1 year license!
Link
mfG
Trapped
Kein Support per PN/Mail
