Files Inspector Prо 1.05 & Ballistic Attack
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Files Inspector Prо 1.05
There are many tools to automatically clean your PC, but none of them can free up significant volumes of disk space. This is mainly due to the fact that quite small pieces of information are removed from the system, which will reappear over time. However, there is a method of manual cleaning, which frees up much more space for a long time.
Files Inspector Pro works with your files and folders, rather than system files. It allows you to see what info occupies the media in your PC: photos, documents, movies, music, and more. You can view all these and delete the unwanted files, if necessary.
Files Inspector Pro is easy to work with. After starting the app, you will see the main sections “Images”, “Downloads”, “Apps and Games”, “Music”, etc. The utility analyzes their contents and displays the space occupied by partitions in the form of diagrams.
Capabilities
Express analysis of user files
Advanced analyzer
Deletion of unneeded data
Deleting unneeded files and folders
Removing unneeded applications
Safety
PRO Compressing photos without the loss of their quality
Link
Game Giveaway of the day — Ballistic Attack
Ballistic Attack is a classic defense of its base in an unusual and vivid setting. Defend the base and gain points of improvement. Hordes of enemies will try to break through the defense. Give them a hard fight with the Ballistic Attack. Defend the approaches to your base, to withstand several attacks using 10 types of steep weapons with the possibility of improving it.
Link
mfG
Trapped
Kein Support per PN/Mail
