1AV Image Converter 1.0.0.91 & Forest Guardian
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — 1AV Image Converter 1.0.0.91
1AV Image Converter hilft euch beim Konvertieren von Bildern und unterstützt eine Menge Formate wie zum Beispiel JPG, PNG, GIF, BMP, TIF, TIFF, ICO, PDF, DPX, J2C, J2K, JP2, PAM, PBM, PCX, PGM, PPM, RAS, RGB, SGI, TGA, WEBP, XBM, YUV, VIFF, WBMP, WMF, WPG, XCF, XPM, AAI, ART, ARW, AVS, BPG, BRF, CALS, CGM, CIN, CMYK, CMYKA, CR2, CRW, CUT, DCM, DCR, DCX, DDS, DJVU, DNG, EMF, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EXR, FAX, FIG, FITS, FPX, GPLT, GRAY, HDR, HPGL, HRZ, JBIG, JNG, JPEG, MAN, MAT, MIFF, MNG, MRW, MTV, MVG, NEF, ORF, OTB, P7, PALM, PICT, PIX, PNM, PPM, PSD, PTIF, PWP, RAD, RAF, RGB, RGBA, RFG, RLA, RLE, SCT, SFW, SUN, SVG, TIM, UYVY, VICAR.
1AV Image Converter hilft euch darüber hinaus beim Skalieren und Drehen von Fotos und fügt euren BildernText/Grafik-Wasserzeichen hinzu.
Bitte beachtet: Dieses Giveaway beinhaltet eine lebenslange Lizenz.
Link
Game Giveaway of the day — Forest Guardian
Forest Guardian - a simple 2D platformer with elements of survival, which is suitable for people of all ages. In this game you have to survive for a little magician among the variety of monsters. Your main objective is picking up the vials of potion. After you collect them, you will open the door, passing through which, you will be taken to the next level. Kill the enemies using your magical skills, but be careful, the enemies have their own abilities that they will use, not to allow you to collect the coveted bubbles.
Link
mfG
Trapped
Kein Support per PN/Mail
