UniPDF 1.3.1 & WonderFox HD Video Converter Factory Pro 18.1 & Sky hurricanes
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — UniPDF 1.3.1
UniPDF is developed based on the primary concept of re-producing a Word file from a PDF. It comes with a series of features which makes the task even more effective and efficient. In usage, it is versatile. It supports converting PDF files to Word, image, text and HTML. One of the most attractive features of this software is that it retains the original design and layout of the PDF. Conversion time is barely sensible. Time you can save on copying and pasting PDF content is not minutes, but hours.
Unique Features include:
Convert your PDF files into four file types to meet your specific needs: Microsoft Word, image, text and html files are all available.
Retain original design and formatting: Converted files will retain original layout and formatting of the original document to save you time having to re-edit your documents to get them the way you want them.
Convert PDF files in batch: Convert PDF files individually or convert multiple files in a single session.
Super-fast conversion: Lightning fast conversion speeds enable you to spend less time converting and more time getting work done.
Convert a selected page range: Convert entire documents or select only specific pages within a document for conversion.
A user friendly interface that anyone can use with ease. Simple drag and drop interface allows you to easily select which files you’d like to convert.
Supports 20 UI Languages.
Link
Giveaway of the day — WonderFox HD Video Converter Factory Pro 18.1
WonderFox HD Video Converter Factory Pro ist ein hervorragendes Programm zum Konvertieren von HD-Videos. Es wird von der exklusiven Videokodierungstechnologie WonderFox unterstützt und zeichnet sich durch vielfältige HD-Videokonverter aus, die eine höhere Ausgabequalität erzielen.
In der neuesten Version wurden nicht nur Bildschirmaufnahme, GIF-Erstellung und weitere nützliche Funktionen hinzugefügt, sondern auch die Videobearbeitungsfunktion wurde erheblich verbessert. Das Tool unterstützt Schneiden, Hinzufügen von Spezialeffekten und Wasserzeichen und vieles mehr.
Hauptmerkmale:
Unterstützt Hardware-Codierung für NVIDIA NVENC, CUDA und Intel HD Graphics-Hardwarebeschleunigungstechnologie, die zu einer hohen Geschwindigkeit beiträgt.
Konvertiert HD-Videos in allgemeine Videos und reduziert die Videogröße ohne Qualitätsverlust.
Konvertiert SD-Video in HD-Video (verbessert die Videoqualität mit dem fortschrittlichen HD-Videokodierungskern).
Lädt Videos in 8K, 4K, 1080P, 720P, 480P von über 300 Webseiten herunter.
Konvertiert Audiodateien und verfügt über ein integriertes Klingelton-Tool.
Bietet einen integrierten Editor (Zusammenführen, Hinzufügen von Untertiteln, Zuschneiden, Drehen, Anpassen der Lautstärke usw.)
Müheloses Aufzeichnen des Bildschirms.
WonderFox HD Video Converter Factory Pro lebenslange Lizenz (1 PC). Nur $19.95 (Normalpreis $39.95 ).
WonderFox HD Video Converter Factory Pro Familienpaket (3 PC) - nur $54.95 (Normalpreis $79.95).
HD Video Converter Factory Pro+WonderFox DVD Ripper Pro Goldpaket - nur $29.95 (Normalpreis $ 69.95).
Link
Game Giveaway of the day — Sky hurricanes
advanced aircraft in the world.
Your task is to overcome nine levels at which you will be met by many opponents.
You will be confronted by unmanned flying drones, helicopters, airplanes, air mines ...
The commanders-in-chief, who will try to destroy you on their flying means, are also of great danger.
Pick up weapons and upgrades for your aircraft. You have access to the power shield, which is able to repel most of the enemy’s attacks.
All in your hands!
Features:
-Various enemies
-Dynamic gameplay
-9 levels
-Difficult gameplay
Link
mfG
Trapped
Kein Support per PN/Mail
