VideoProc 3.4 (Win&Mac) & SecureAPlus Essentials 6.0.1 & TOXIC PLUMBING
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — VideoProc 3.4 (Win&Mac)
VideoProc is an all-purpose, yet simple to use software that combines strong video editing, video/audio/DVD conversion, downloading and recording functions. By utilizing unique level-3 GPU acceleration, it is skilled at fleetly processing 4K/8K/HD, large-sized and high-speed videos from cameras, phones, Drones, etc. You will also be impressed with its user-friendly operation, neat features, smooth performance and high quality output.
Never been easier to process your videos with VideoProc:
Editing: cut, split, crop, merge, resize, reframe (30/60/120/240fps), add effect/subtitle/watermark, make Gif, etc.
Repair: stabilize, denoise, defisheye, rotate/mirror, slow down or speed up footages, force A/V sync, etc.
Adjusting: compress video size, customize bit rate, resolution, GOP, encoding mode, 4K to 1080/720p and more.
Convert: any old/new DVDs, videos, audios to any video audio formats for playback 420+ profiles.
Download: save video, audio, playlist and channel from 1000+ UGC websites. Support batch downloading.
Record: capture computer/iOS screen; record video with webcam and remove/change background from a webcam.
What's new in V3.4?:
Added new output profiles for iPhone 11, 11 Pro/Pro Max and new Apple TV, etc.
Enhanced video processing engine to support videos from various new cameras.
Improved GPU acceleration docking tech to process H.264 and HEVC video faster.
Bonus: Digiarty also provides you a unique chance to gain Lifetime Full License at 60% off discount.
Link
Giveaway of the day — SecureAPlus Essentials 6.0.1
SecureAPlus is security software that protects PCs from malware and viruses with its powerful but easy to use Application Whitelisting, and reliable detection rates of more than 10 cloud Anti-Virus engines with Universal AV. It leverages the power of the cloud allowing for low resources used and compatibility with other installed anti-virus and anti-malware applications making it the perfect security upgrade for any Windows PC.
SecureAPlus now has a companion app on Android phones. You can download the SecureAPlus Antivirus for Android by visiting this page. To add the mobile device to your SAPPortal Account by logging in to the Android App, please consult the following support page.
Note: the program includes a two-year license! You can take a look at the short registration instruction here
Link
Game Giveaway of the day — TOXIC PLUMBING
Toxic threat covered trees which are struggling. You must help the trees, clearing them of toxins, allowing them to re-bloom.
Game Plumbing "Toxic threat" is of the long-known genre of "plumber ", but you will be pleasantly surprised by the changes that bring variety to the gameplay. The game will be interesting for everyone from novices to pros.
The game has 20 levels, which differ:
- Simple levels - which will help you to practice logic games and how to construct a pipeline. At these levels have no restrictions, can be long and hard to find the right solution;
- For time – after simple training levels, we will complicate the task, now every level has a time limit, be careful while choosing the desired position of pipes, if time runs out, you have to start the level again;
- With limited turn-out of pipes, can you easily cope with the levels on time ? Then let's complicate the task now each pipe can only be turned 4 times, after those it will break, be careful, because there are the pipes without which you can't force in to the correct path of the pipeline. In advance, think before you twist the tube and watch the time;
- Filter – and here are the new levels, now at level, there is a filter that separates the toxins into the water and poison. Here it is necessary to hold the pipe to the filter and from the filter to the pipe in two directions, clean water back to the tree, but the poison to collect in the barrel, also do not forget about the separation of turn-outs and time;
-With different directions – and finally, the most difficult levels. Here you will have to think carefully, because the correct version of the pipeline is only one, you need to correctly make a plumbing, but at some point it will be split into two or even three directions, which extremely complicates task, and you shouldn't forget about the time and limitation of the turn-outs of the pipes.
Link
mfG
Trapped
Kein Support per PN/Mail
