jaro44
Beiträge: 37 Registriert: Di 12. Apr 2016, 18:04
Box: tank, trinity duo, xsarius alpha hd
Beitrag
von jaro44 » Fr 3. Jan 2020, 20:03
After update image on my box I don't have signal ( I reset to factory default and is same)
I back to 3.40 and all is ok, so I install newest nightly from usb and again is "no signal"
I had to go back to the old image
PS.
My antenna instalation:
multiswitch
diseqc 1.0
hotbird 13E - 1
astra 19.2E - 2
Beiträge: 1251 Registriert: Di 5. Apr 2016, 17:17
Has thanked: 17 times
Been thanked: 12 times
Beitrag
von Miky » Fr 3. Jan 2020, 20:12
Have you tried without own settings? SAT Scan also done and not your old Zapit?
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 20:20
after update I make factory reset and make new configuration, so this is no problem with config.
with box and instalation also, because on old 3.40 image all work ok
Beitrag
von Miky » Fr 3. Jan 2020, 20:27
If you came from NI, you don't need a factory Resett. 3.4 is more than 2 years old, I don't know all the changes in 2 years. Have you tryed with other diseqc Settings?
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 20:30
I had 3.60 from November, and this I update yesterday and have those probleme
Zuletzt geändert von
jaro44 am Fr 3. Jan 2020, 20:45, insgesamt 1-mal geändert.
Beitrag
von Miky » Fr 3. Jan 2020, 20:36
You mean yesterday not tomorrow? Why 3.6 from November?
I don't understand really what you wrote.
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 20:44
yes yesterday, my mistake
previous last update nightly 3.60 I did in November, and he worked ok until yesterday
Beiträge: 3958 Registriert: Di 5. Apr 2016, 16:52
Has thanked: 1 time
Been thanked: 29 times
Beitrag
von tewsbo » Fr 3. Jan 2020, 20:55
my both tanks and the zee² works with the nightlies from today (03.01.) without problems.
ich nutze ei
rres Image
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 20:57
with same antena and diseqc instalation?
I now install keywelt 3,92 and also work ok for me, newest NI not
Beitrag
von Miky » Fr 3. Jan 2020, 20:59
My Tank Image is from 20.12.19 and everything okay. Can't update it now but tewsbo with 3 boxes should be enough.
Has thanked: 1 time
Beitrag
von tewsbo » Fr 3. Jan 2020, 21:01
jaro44 hat geschrieben: ↑ Fr 3. Jan 2020, 20:57
yes, diseqc etc. the same - see for my sat-settings also my signature.
ich nutze ei
rres Image
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 21:06
so, with my instalation this is bug for me (multiswitch with diseqc 13E - 1, 19,2E - 2)
I wait for fix and stay with newest keywelt, because it work ok
Beitrag
von Miky » Fr 3. Jan 2020, 21:11
No problem. It can only be solved by providing a log.
jaro44
Beitrag
von jaro44 » Fr 3. Jan 2020, 21:26
ok, I'll try to log it after weekend
nofx
Beiträge: 115 Registriert: Sa 16. Apr 2016, 10:22
Has thanked: 5 times
Beitrag
von nofx » Sa 11. Jan 2020, 15:37
I have similar issues see log..
astra 19.2E - ok, no issues
hotbird 13E - issues
[fe0/0] Diseqc cmd: 0xE0 0x10 0x38 0xF4
[fe0/0] Diseqc cmd: 0xE1 0x10 0x38 0xF4
[fe0/0] tune to 10758000 DVB-S2 8PSK 3/4 V/R srate 27500000 pli 0 plc 1 plm 0 (tuner 1008000 offset 9750000 timeout 4000)
[sdt monitor] wakeup...
[sdt monitor] TP already updated less than an hour ago.
[fe0/0] ############################## poll timeout, time: 4020 msec (min 2000 max 4064)
[zapit] ZapIt:1 SCR retry tuning 1 after 4ms
CRemoteControl::handleMsg: EVT_TUNE_COMPLETE (0000000000000000)
CVFD::showServicename: (4Fun.TV)
CVFD::ShowText: [0x10][(4Fun.TV)]
zap failed!
jaro44
Beitrag
von jaro44 » Mo 13. Jan 2020, 19:27
install the latest keywelt_Jun2019_V3.92 and everything will be ok
Beitrag
von Miky » Mo 13. Jan 2020, 19:34
jaro44 hat geschrieben: ↑ Mo 13. Jan 2020, 19:27
I still wait for your log.
jaro44
Beitrag
von jaro44 » Mo 13. Jan 2020, 20:41
Miky hat geschrieben: ↑ Mo 13. Jan 2020, 19:34
everything works fine on keywelt, so i didn't reinstall it to NI,
maybe I'll log it in my spare time, but as You can see the problem is more widespread,not only at my box
Beitrag
von Miky » Mo 13. Jan 2020, 22:16
jaro44 hat geschrieben: ↑ Fr 3. Jan 2020, 21:26
If you won't log, no help possible.
Otherwise are post likes : "Use Keywelt and everything ist easy" not really helpful.
You posted and asked for support but you are not able to flash NI again for logging?Incomprehensible.
nofx
Beitrag
von nofx » Di 14. Jan 2020, 07:36
Last working img (own build) is from 2019.11.14, the next one which I have is from 2019.12.27 and since them I have these kind of issues with hotbird 13E.
So something was changed between these dates.
