MSTech Easy Desktop Organizer Pro 1.14.33 & ALLCapture 3.0 & Romguns
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — MSTech Easy Desktop Organizer Pro 1.14.33
NB: The software requires .NET Framework 4.8 or higher
Most of us keep our frequently used files, folders, and applications' shortcuts for quicker access.
Most of the time, we will end up with a messy, confusing desktop.
MSTech EDO, helps you to have access to your files, folders, and shortcuts, while you have a clean and organized desktop.
You can create an unlimited number of windows on your desktop, show or hide them as you need. Easily keep unlimited files, folders, and shortcuts categorized by your style just by drag and drop them over the windows.
Each window comes with a built-in search tool, which makes you able to find your desired file or folder easier and faster.
Furthermore, you can manage your desktop wallpapers/backgrounds directly through the software. Also, you can enjoy downloading free high quality (HD) desktop wallpapers from the MSTech website.
The Giveaway Promotion Details:
- No Free Update
- No Free Upgrade
- No Free Support
- No Commercial Use
SPECIAL OFFER FOR GOTD:
Buy MSTech Easy Desktop Organizer Pro v1.14.33 + FREE UPGRADE to v2.0 + FOR 1PCs - 60% OFF ($9.99).
One Day Only.
OTHER OFFERS FOR GOTD USERS ONLY TODAY:
1. MSTech Golden Pack Lifetime Upgrade $550.00 $29.99 %94
2. MSTech Silver Pack Lifetime Update $550.00 $24.99 %95
3. MSTech Bronze Pack 1 Year License $200.00 $14.99 %92
4. Folder Icon Pro $55.00 $9.99 %81
5. Swift Gadget $55.00 $9.99 %81
6. Search in Contents Pro $45.00 $9.99 %77
7. Search in Contents Basic $30.00 $5.99 %80
8. Image Resize Basic Basic $20.00 $5.99 %70
9. Easy Desktop Organizer Basic $15.00 $5.99 %60
10. Check Writer Pro $210.00 $14.99 %92
11. Check Writer Basic $210.00 $9.99 %92
Link
Giveaway of the day — ALLCapture 3.0
ALLCapture lets you record anything on your screen in real-time, even fluent movements such as online conferences and CAD-3D simulations can be professionally recorded. Various functions (balloons, notes, etc.) and special effects (elastic band, spotlight effects, etc.) offer an easy way of editing your recordings. Multiple export formats are available (Flash, EXE files, ASF and video files for the publication on CD, DVD, VCD and SVCD).
Start and stop screen recording with one click
Configure the recording window to meet required size
Support of full screen and multi-screen recording
Recording of overlapping windows and program interactions
Improved frame logic for better video capture and smaller file size
Standard Windows Interface: intuitive timeline for easy and effortless editing
Memory Manager: allows to swap video footage to external media (e.g. hard drive, flash drives or USB sticks) in order not to compromise the PC's performance
Link
Game Giveaway of the day — Romguns
In some low-welfare states, residents prefer to earn a living by kidnapping and extorting ransom from relatives.
Every year, about 3 thousand people disappear.
And one day they abducted the wife of Roman Rombo, a former commando, armed to the teeth, he went to save his beloved from the clutches of the kidnappers!
ROMGUNS is a dynamic and hardcore platformer, action shooter with a side view.
in the arsenal of the hero there are 3 types of weapons, a pistol with an inexhaustible supply of ammunition, an assault rifle and a shotgun, there are also grenades.
Features:
- Colorful pixel graphics
factory soundtrack
- external appearance of enemies is randomly generated
- Armament of enemies is randomly generated
-20 levels
bosses
Link
mfG
Trapped
Kein Support per PN/Mail
