iObit Software Updater Pro 2.4
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — iObit Software Updater Pro 2.4
Outdated software may leave some risks to your PC. It’s better to keep all software up-to-date. With 180% larger software database, IObit Software Updater can automatically scan and update your software in scheduled time without bothering you, and you just need to list your software in the "Auto-Update List".
Having no idea which software is the right one or bothering to install your needed software one by one on websites? IObit Software Updater gives you the best solution by recommending trustworthy and popular programs for you to install from within this software. All these programs have been already well classified according to their functions, so you can select and install your needed ones instantly and easily.
Worried about the software updating process? You don't have to. To avoid a long wait during software downloading, the latest IObit Software Updater used a new algorithm to help to download 10% faster. Also, IObit Software Updater uses strict criteria to make sure you've got the clean software and not annoyed by ads or bundleware or even malware while installing software.
Please note: the program updates to the Pro version upon license registration.
Link
mfG
Trapped
Kein Support per PN/Mail
