Abstract Curves 1.190 + Bonus Presets Pack & Audials TV Recorder 2020
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Abstract Curves 1.190 + Bonus Presets Pack
AbstractCurves is an image generator which allows you to create stunning wallpapers/backgrounds or posters in any resolution, or add effects or logos/watermarks to your photos. AbstractCurves includes a variety of built-in presets, and gives you the ability to create user presets. This program is available as a standalone application, and as a plug-in to the most popular graphic hosts, such as Adobe Photoshop, Adobe Photoshop Elements, Corel Paint Shop Pro, IrfanView, and others which support .8bf files. The installer includes 4 versions: Standalone (32-bit), Standalone (64-bit), Plugin (32-bit), Plugin (64-bit).
Discover unique opportunities with the powerful features of AbstractCurves:
Unlimited number of effects;
More than 10 galleries with 130+ built-in presets;
Ability to create and save your own presets;
Ability to set any color of generated image and background;
30+ built-in color palettes with 7000+ colors;
Ability to create and save your own palettes;
Adding generated images to your photos;
Transparent background option for creating logos, icons, avatars, etc.
16-bit image support.
Bonus Presets Pack includes 155 new presets in 15 galleries!
Link
Giveaway of the day — Audials TV Recorder 2020
Over 300 live streams of TV channels from the United States, United Kingdom and other countries are at your disposal. You will not miss a broadcast anymore and are always well informed. If you are interested in a program, you record it with one click. If you find more livestreams, you can manually add them via link.
Link
mfG
Trapped
Kein Support per PN/Mail
