FolderIco 6.2.1
trapped
Been thanked: 3 times
FolderIco 6.2.1
Beitrag von trapped »
Giveaway of the day — FolderIco 6.2.1
FolderIco allows to customize the icon of every Windows folder in one click! Don't you know how to change standard yellow folder to a colourful and bright one? With FolderIco, give some colors to Windows folders. With just a one click, colorize your folders, and discover a new intuitive way to classify your files. A quick look is now enough to identify the folder you are looking for!
FolderIco is a very light software, that doesn't stay in memory. It uses a native functionality of Windows to be more efficient. Discover its simplicity: with a single right-click on a folder you change it icon!
Link
mfG
Trapped
Kein Support per PN/Mail
