Spektrel Art (Win&Mac) 1.1.8 & PianoTeacher 2.0.0.1
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Spektrel Art (Win&Mac) 1.1.8
See more pics here
Spektrel Art is an extravagant otherworldly display of undulating movement that glimmers and gleams with intersecting lines of tapered light. Applied to photos, this medium of imaginative and magical art form transcends the ordinary to extraordinary creating something wild, sparkling with life and colorful spaces.
SPEKTREL ART INCLUDES
Presets to start you off
Detail slider to increase the amount of intersecting lines
Glow options add colorful edges and splendrous brillance
Taper Length and Sharpen sliders to add twinkle
TLighten and Brighten sliders to make it illuminate
TEdge Detail slider to exaggerate the lines
TSmoothing slider to softens lines
TColor Boost for enhanced color
TBrushes to soften or remove effect
TInfinite variation for illuminated twinkles, fluid lines and ethereal softness
Link
Giveaway of the day — PianoTeacher 2.0.0.1
PianoTeacher is an ideal solution to learn music using your computer.
PianoTeacher is a very useful application for piano and music learners. The application contains piano lessons, piano exercises and piano pieces. The program can automatically generate new piano exercises. PianoTeacher contains a music notation module as well.
Supported audio file formats: Wave audio files, Mp3 audio files, OggVorbis audio files and MIDI files.
Features:
Learn to play piano using your computer.
Quick create piano exercise.
Export project file to MIDI file.
View and print music-notation.
Add lyrics to MIDI file.
Playback MIDI file.
Playback supported audio file.
Improve the sound quality with the 10 bands equalizer.
Record Wave, Mp3 and OggVorbis audio files.
Record vocals using microphone.
Record streamed audio data.
Play and sing your own song and record it to your hard disc.
Save your work as a project file and open it whenever you like.
Link
mfG
Trapped
Kein Support per PN/Mail
