Selfie Studio 2.17 & 1Tree Pro 5.0 & Zball III
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Selfie Studio 2.17
Selfie Studio provides you with the creative tools to edit your photos and get the look you want. A Pixarra product in the Studio series, Selfie Studio builds on the success of other Studio products by Pixarra, giving you a tool dedicated to achieving your photo vision quicker and better than other options.
Link
Giveaway of the day — 1Tree Pro 5.0
Shows the size of all drives/folders/files in 1 tree view:
Operate resources in batch mode;
Sort resources by size in descending order;
Intelligent unit and decimal for resources size;
Common commands and copy full path;
Customizable interface.
Please note: 1 Year Single License (1 PC) with 1 Year Upgrades is included in this version. Click here to get a VERY BIG discount for other Lifetime licenses with Lifetime Upgrades on the promotion day!
Link
Game Giveaway of the day — Zball III
Zball III is the return of physics puzzles series.
This game has puzzles about changing the direction of gravity.
There are 2 types of objects that can change the direction of gravity.
The 1st one is a button - just press it to change the direction of gravity. The 2nd one is an activated object that change gravity when it collides with a green ball.The rest of the game rules remain the same.
Blocks can have different powers - some can be destroyed when colliding with other objects or from an explosion, some are monolithic but mobile, some can mve the green ball. Most often, there is no specific algorithm of actions, you should rely only on your intuition to solve the problem.
Platforms interact with objects in different ways. For example, there are platforms that make round objects roll in a certain direction. There are transparent platforms that are divided into colors and can only interact with objects of their own color.
There are game levels of different difficulty and types. Some levels require dexterity and reaction, some will require patience and caution, others will make you think about the sequence of actions. You can see how to interact with an object by its color. For example, green is the main color, and you need to deliver it to the platform of the corresponding color. Yellow object reacts to explosions from mouse clicks.
Blue objects are destroyed when they collide with yellow ones. Blue ones are not destructible, but they can be moved by yellow objects. Red objects break down from the explosion…
Gradually you will understand how the system works and will be able to cope with any task! Exciting gameplay will not let you get bored!
Game Features:
40 new levels
Interesting puzzle
Destructible blocks
Gravity puzzles
Steam achievements
Some levels are really hard!
Link
mfG
Trapped
Kein Support per PN/Mail
