Seite 1 von 1
Cables.xml für Vodafone Kabel Deutschland
Verfasst: So 14. Feb 2021, 14:10
von Peter59
Hier mal die aktuelle cables.xml für Vodafone Kabel Deutschlnd.
Diese enthält alle genutzten Frequenzen unabhängig von der jeweiligen Kabel Ausbaustufe.
	<cable name="Vodafone Kabel Deutschland" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="73000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="466000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="474000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="482000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="490000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="498000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="522000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="530000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="538000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="546000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="554000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="562000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="570000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="578000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="586000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="594000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		</cable>
Die vorhanden Kabel Deutschland Einträge können somit entfernt werden.
Re: Cables.xml für Vodafone Kabel Deutschland
Verfasst: So 21. Feb 2021, 19:36
von palace
Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Bei mir werden ein Haufen Sender nicht gefunden.
U.a. das gesamte ARD und ZDF Buquet.
Verfasst: So 21. Feb 2021, 19:47
von Don de Deckelwech
scanne mit NIT gleich EIN, dann sollte alles gefunden werden, mit jeder Liste... ;)
Verfasst: Mo 22. Feb 2021, 11:39
von Gorcon
Don de Deckelwech hat geschrieben: ↑So 21. Feb 2021, 19:47 Hi,
Funktioniert allerdings nicht mit VU+ Uno4kSE
Verfasst: Mo 22. Feb 2021, 20:44
von palace
Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Ich weiß, dass Sender, die nicht gefunden werden, vor dem Scan funktionierten.
Z.B. „Das Erste“ oder „ZDF HD“.
Ich bin auf einer ZEE2 unterwegs.
Interessanter Weise verhielt sich das bei einem Kumpel identisch.
Nur der hat die „Chance“ genutzt, direkt auf eine Dream umzusteigen.
Gibt es hier noch einen User aus BW, der mir aktuelle Services, Bouquets und das dritte (fällt mir grad nicht ein) zur Verfügung stellen kann?
Verfasst: Di 23. Feb 2021, 01:14
von mirz
Verfasst: Di 23. Feb 2021, 10:57
von palace
mirz hat geschrieben: ↑Di 23. Feb 2021, 01:14 ist hier nichts zu finden?
https://helpdesk.vodafonekabelforum.de/ ... egung.html
Cool, danke. Den kannte ich nicht.
Verfasst: Di 23. Feb 2021, 11:15
von Gorcon
palace hat geschrieben: ↑Mo 22. Feb 2021, 20:44 Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Dann hat Vodafone in der Tat keine funktionierende NIT.
Verfasst: Di 23. Feb 2021, 16:30
von Peter59
palace hat geschrieben: ↑So 21. Feb 2021, 19:36 Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Nein, die funktioniert nicht für das exUM Gebiet, nur für wie im Betreff erwähnt exKabel Deutschland.
Für das exUM Gebiet dürfte die cables.xml nutzbar sein:
<?xml version="1.0" encoding="iso-8859-1"?>
<cables>
	<cable name="Unitymedia" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="114000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="130000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="138000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="146000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="154000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="162000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="170000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="178000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="186000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="194000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="202000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="210000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="218000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="226000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="234000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="242000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="250000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="258000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="266000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="274000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="282000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="290000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="298000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="9" modulation="3"/>
	</cable>
	</cables>
Verfasst: Sa 11. Apr 2026, 14:07
von jokel
nachdem vodafone hier in berlin bissel im kabel was umgestellt hat ..
hier die aktuelle cables.xml für berlin .. die kanalsuche war in 30 sek. erledigt.
kleiner tipp am rande .. löscht vorher die ..
/var/tuxbox/config/zapit/services.xml
cables.xml
(2.85 KiB) 232-mal heruntergeladen
Verfasst: So 12. Apr 2026, 00:49
von Nanobot
Hierzu der Hinweis von mir: Die Umstellung findet in Berlin in den einzelnen Stadtbezirken zu verschiedenen Zeitpunkten statt, welche man hier ersehen kann:
https://helpdesk.vodafonekabelforum.de/ ... ng-11.html
Ich habe zusätzlich eine Email erhalten, in der ich über den bei mir zutreffenden Zeitpunkt informiert worden bin. Das kann aber natürlich nur dann passieren, wenn man den Kabelanschluß "offiziell" hat und Vodafone daher eine Email Adresse kennt.
@jokel
Was sollen denn die ersten drei Zeilen in der Datei von dir darstellen ? Dies sind doch gar keine TV-Frequenzen, oder benutzt die "Gigabox" diese Frequenzen irgendwie ?
Verfasst: So 12. Apr 2026, 08:18
von jokel
die datei wurde von vodafone erstellt bzw. habe ich sie erstellen lassen ..
und ja die 3 zeilen kannst du löschen .. sie bringen keinen mehrwert bzw. nutzen.
bei mir war das problem das jetzt durch die mehrmalige umstellung im kabel ..
ich nach der kanalsuche viele sender doppelt drin hatte ..
also habe ich die services.xml gelöscht .. rebootet und danach mit der neuen cables.xml ..
eine auto-kanalsuche gestartet .. und habe jetzt eine jungfräuliche services.xml ..
ohne doppelten einträge mehr.
es wurden 342 sender (tv+radio) gefunden .. wird immer weniger :nerd:
Verfasst: Mo 13. Apr 2026, 00:33
von Nanobot
Ja, die Zahl der Sender wird einerseits dadurch weniger, daß viele Sender nur noch in HD gesendet werden und die SD Ausstrahlung beendet wurde. Um zum anderen wurden ja viele der Sky Sender auf IPTV umgestellt.
Ich träume ja immer noch davon, daß die privaten werbefinanzierten Sender endlich einsehen daß es von den meisten Verbrauchern nicht akzeptiert wird, daß man für Werbung in HD extra bezahlen soll. Sprich, sowohl die SAT1, als auch die RTL Gruppe sollten die Verschlüsselung der HD Versionen aufgeben und die SD Abstrahlung ihrer Sender ebenfalls beenden. Dann wäre noch viel mehr Platz im Kabelnetz für andere Sachen.
