Creativities.PDF 1.2.0 & Desert Fear
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Creativities.PDF 1.2.0
Creativities.PDF is an all-in-one application for managing and converting PDF files. It provides basic functions for editing PDF files, such as rotating, deleting and extracting pages, text recognition in PDF and image files, adding or removing password protection, converting Office documents and images to PDF. Furthermore you can merge multiple files into one single file, export images that are embedded in a PDF file and compress a PDF file.
An OCR module is also included. This allows you to convert non-searchable documents (for instance, PDF files that include scanned pages with text) into searchable ones or extract text from images.
Creativities.PDF performs all the processing locally, on the user’s computer, without uploading your files online.
Link
Game Giveaway of the day — Desert Fear
Your group is an elite special forces for the destruction of monsters. This time you have to destroy monsters in an abandoned city. It looks like the task will not be easy. Monsters are very dangerous and fast. Use all weapons and help your soldiers.
Link
mfG
Trapped
Kein Support per PN/Mail
