AllMyNotes Organizer Deluxe 3.41 & Filme 3.3.1
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — AllMyNotes Organizer Deluxe 3.41
AllMyNotes Organizer provides an alternative concept of random info management. It's simply a free form data management app, one of the best of its kind. It provides all needed tools (notes, tables, alarms, checkboxes, etc.), so you can organize your info exactly the way you like! No more limits, no strictly defined fields, just feel the idea and start organizing your info environment brick-by-brick right now!
Key features:
Hierarchical organization of your random text and graphic information (a free-form outline tree);
Rich-text editor which supports: Tables (including sorting), Alarms, File attachments (with preview for images), Call phones by double-click (Skype, or any other voip app);
Instant real-time search across all your information;
Secure and advanced data storage format (support >4Gb files, very fast, 1800-bit low-level data encryption, to assure that there will be no traces of your sensible data on a disk), with fee import and export.
Reminders;
In-text calculator. For example, you can type "2+2=" and it will put 4 automatically;
Scanner support;
AutoCorrect feature. For example, if you type "(c)", it will be corrected to ©;
Strong password generator feature for generating highly secure passwords;
Quick data capture (via system tray icon);
Rich drag&drop capabilities;
Automatic backups (history);
Import/export from/to (html, rtf, knt, txt, gif, png, bmp, jpeg, and some others);
Free edition is available for data access and limited editing on PCs where Deluxe edition is not installed;
Translated in ~30 languages;
Skins/Themes.
Link
Giveaway of the day — Filme 3.3.1
1. Create a slideshow fast with fast video mode. Use multiple templates to keep your video creative.
2. Add more than 170+ effects like filters and animations and 110+ transitions to create vivid and refined digital stories.
3. Instantly preview the video while editing. Play 8+ audio tracks simultaneously.
4. One-click upload to Facebook\Twitter\YouTube\Vimeo platforms.
5. Support recording and screen recording function and one-click background music replacement.
6. Support importing materials via wireless devices or scanning the QR code.
Link
mfG
Trapped
Kein Support per PN/Mail
