Domain Checker 6.5 & MSTech PDF Split Merge 1.4.13 & Mahjong Gold 2: Pirates Island
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Domain Checker 6.5
Check availability of multiple domain names at once. Obtain domain name status information with this effective and intuitive application that allows you to batch process multiple entries.
Domain Checker is a simple, but powerful whois lookup tool for users that require a bulk domain availability checker software. The software supports the most common top-level domains (TLD), and users are free to add new ones. Anyone interested in releasing new websites will benefit from this utility, as it allows one to check for domain name availability. The ability to batch process multiple entries makes it a worthwhile tool, when several options are being considered for the future site. The application features an efficiency-geared GUI that allows one to quickly generate simple or advanced scans.
Domain Checker employs several auxiliary windows, which are accessed either from menu, or from the large topside buttons. Besides manual input of desired items, one can also import lists from files.
Key Features:
* Built-in support for 400+ TLDs
* User editable whois server list
* Proxy server (SOCKS) connection
* Domains from Word-list
* Internationalized domain names (IDN)
* Emoji domain names
* Domains by Char
* Domains by Formula
* Domains for all TLDs
* Domain Wizard
* Cross-Mix Words
* Can handle up to 100 million rows
Link
Giveaway of the day — MSTech PDF Split Merge 1.4.13
It happens when you want to send a PDF file via email, or you need to extract some pages from a larger/main PDF for any purpose like writing an article, etc. MSTech PDF Split Merge helps you to split your PDF file(s) in single and batch mode, with various options such as split your files every ‘n’ page(s), split into ‘n’ files or even custom ranges.
Even for the times you want to merge several PDFs into one file, for example merge different chapters of a book, different pages of an article, etc. You just need to add the files to the software, then use the simple option to merge the entire PDFs in the defined order in to one file, or you can specify the page ranges you need from each pdf with the exact order. The software will merge them as you want.
MSTech PDF Split Merge is a small, yet powerful with various option to Split or Merge any PDF File. You just need three simple step:
1- Add the files
2- Adjust the settings
3- Click (Split/Merge)
Why MSTech PDF Split Merge?
MSTech PDF Split Merge, comes with a built in PDF viewer which makes your job easier to select the pages you need to split, extract or merge. It also supports encrypted or password protected PDFs in both Split and Merge.
SPECIAL OFFER FOR GOTD:
Buy MSTech PDF Split Merge v1.4 + FREE UPGRADE to v2.0 + FOR 1PCs - 50% OFF ($7.5). One Day Only.
Link
Game Giveaway of the day — Mahjong Gold 2: Pirates Island
Exclusive offer from Giveaway of the Day and ToomkyGames! No third-party advertising and browser add-ons!
Set sail from Port Royal on the Golden Hind and head for Hard Luck Island. Legend has it that untold treasures are hidden there. The treasure trove's location is encoded in special tiles which you will have to remove to reach the gold! The greed and generosity of pirates knew no bounds. The smuggler's path wasn't easy – goals and limited moves will present a serious challenge to your abilities in Mahjong Gold 2: Pirates Island!
Link
mfG
Trapped
Kein Support per PN/Mail
