Joyoshare VidiKit for Windows 1.4.1 & GitMind VIP 1.0.4
trapped
Beitrag von trapped »
Giveaway of the day — Joyoshare VidiKit for Windows 1.4.1
Joyoshare VidiKit for Windows is an all-in-one video toolkit for multimedia users. It offers a one-stop solution to professionally and effortlessly edit videos. Making full use of it, you can cut and trim large files accurately into smaller pieces in original quality, record desktop screen with audio in high resolution, convert media files to desired formats in batch at 60X fast speed. Best of all, there are mighty yet reliable utilities it provides to let better manage and post-process videos, such as video repair and video compressor. If you’d like to furtherly edit and create appealing videos, you’re allowed to merge, watermark, effect, subtitle, rotate, crop, etc.
Key Features:
Cut, convert and merge videos losslessly with high efficiency
Customize capture area and record screen in high quality
Record audio from microphone and computer system
Repair multiple corrupted and damaged videos with high success rate
Compress unlimited videos with 40X amazing speed to reduce file size
Remove watermarks from videos and images magically
Built-in editor to effect, subtitle, crop, rotate and more
Comes with freeware: media player, HEIC and Live Photo converter
High compatibility to support nearly all mainstream multimedia formats and devices
Link
Giveaway of the day — GitMind VIP 1.0.4
GitMind is an easy-to-use mind mapping and brainstorming tool. It can be used to brainstorm, take notes, organize ideas and knowledge, manage tasks and projects, inspire creativity and improve productivity. GitMind saves all changes automatically and sync across your devices seamlessly.
Key Features of GitMind:
• Create from pre-made templates
• Change map theme, layout and style
• Custom background, font, border, line
• Insert images, hyperlinks and comments
• Edit/Generate map outline
• Secure cloud storage
• Sync across your devices
• Share and collaborate online
• Retrieve change history
• Export to PNG, JPG, PDF, TXT, GitMind Project
Three Steps to Make Mind Maps:
1. Click “Use Templates” to copy a template.
2. Fill in the content and customize the style.
3. Click “Export” button.
Link
mfG
Trapped
Kein Support per PN/Mail
