PC WorkBreak 10.1 & Data Extraction Kit for Outlook 3.2.0.0
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — PC WorkBreak 10.1
Wollt ihr das RSI-Risiko (Repetitive Strain Injury - Verletzung durch wiederholte Beanspruchung/Belastung) reduzieren? Dann braucht ihr unbedingt PC WorkBreak! Das Tool bietet euch diverse Pausenerinnerungen wie z.B. Dehnen, Mikroentspannung, Augenübungen und dezente Aufforderungen, ein paar Schritte zu gehen.
Features:
Flexible Pauseneinstellungen;
Professionelle Anleitungen für Dehnübungen;
Pausenstatistik;
Unicode- und Multisprachen-Support;
Bitte beachtet: Die Software beinhaltet 1 Jahr kostenloser Upgrades. Heute haben GOTD-Benutzer die Möglichkeit, einen RIESENRABATT auf lebenslange Updates zu bekommen - nur am Giveaway-Tag!
Link
Giveaway of the day — Data Extraction Kit for Outlook 3.2.0.0
Data Extraction Kit for Outlook is a unique product that combines the functionality of a powerful and fully configurable data extractor with that of a convenient tool for conducting forensic investigations. Its advanced built-in report generation mechanism allows for in-depth analysis of the contents of PST files, allowing security experts and investigators to convert specific emails in PST files to the necessary format.
Data Extraction Kit is intended for professionals and regular users who need a tool for quick and flexible conversion of the contents of Outlook PST storage files into other formats, either for importing into alternative applications, archiving, data migration or other purposes. The new product has all the features conveniently presented in a single main program window for ease of access and navigation. Data Extraction Kit for Outlook works with messages and attachments, contacts, notes, calendar items and other standard objects and converts them into a number of compatible formats, including MSG, RTF, TXT, EML, TNEF, HTML, MHT, VCF, VCS and ICS.
The user can configure various aspects of the conversion process: from the replacement of unsupported characters in message subjects and preservation of the original folder structure to keeping the objects creation date and time intact. In order to facilitate the selection of the necessary items, there are implemented several filters that enable users to select files created before or after a particular date, containing attachments or without them, or being smaller than the specified threshold.
Link
mfG
Trapped
Kein Support per PN/Mail
