Aiseesoft iPhone Cleaner 1.0.18 & Fantastic puzzles 2021
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Aiseesoft iPhone Cleaner 1.0.18
Aiseesoft iPhone Cleaner is the most powerful tool to clean up your device storage and speed up your iPhone. You can free up the space in seconds, like erasing junk files, uninstalling apps, deleting large files, and compressing photos. You can also use it to erase all the data on your device so you are able to sell or give the device to others without leaking your privacy. It will wipe out all your contacts, text messages, music, videos, pictures, password or other information on your iPhone, iPad or iPod. Moreover, it supports all the iOS devices like iPhone 13/13 Pro/13 Pro Max/13 mini, iPhone 12/11/XS/XR/X/8/7/6/SE/5/4, iPad Pro, iPad Air, iPad mini, iPad, and iPod touch. (Just make sure that the latest iTunes is installed on your PC.)
Link
Game Giveaway of the day — Fantastic puzzles 2021
Puzzles with fantastic stories. Each level consists of 60 elements that will have to be rotated to match all the elements. The game contains 12 levels of medium difficulty. The game has a choice of levels and you can start guessing at once any puzzle of your choice. The faster you finish the game, the more points you get, which will be included in the list of records. If you do not have time to finish the game, you can save it and continue playing at any time, each level will be saved separately. With each level, the pictures become a little more complicated. If you are at a loss, then click the icon with a question mark and the game will tell you where to put the desired element. In the game, you can flip through the levels without going through them if they caused difficulty in passing, just press the arrow to the right. The game will delight you with nice graphics and calm music.
Link
mfG
Trapped
Kein Support per PN/Mail
