MacMagic 1.0.6 (MAC) & Portrait Painter 1.37 (Win&Mac) & Terrible puzzles
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — MacMagic 1.0.6 (MAC)
MacMagic can help clear up gigabytes of lost storage space crowded up by the caches of poorly optimized apps, hide and show hidden files in the Finder, help force-delete the contents of the Trash or stubborn files, and perform various other tasks to help automate or simplify your daily workflow!can help clear up gigabytes of lost storage space crowded up by the caches of poorly optimized apps, hide and show hidden files in the Finder, help force-delete the contents of the Trash or stubborn files, and perform various other tasks to help automate or simplify your daily workflow!
Other Highlights
Quit & Restart Finder
Whether you're trying to save RAM and CPU time, or are fighting a pesky bug, easily fully quit and/or restart the Finder.
Force Delete
Pesky files can sometimes evade deletion using the built-in Trash feature. Escalate to super-user privileges and eliminate them.
Combine & Create PDFs
Use our Combine PDFs feature to easily convert any image file to PDF format (the web standard for documents), or add and remove pages from existing documents.
System Tools
Easily access hidden system tools buried deep within macOS such as Screen Sharing, Certificate Utility, File Merge and more.
Lock Files
Recursively lock or unlock entire folders worth of files.
Maintenance
Perform other routine system maintenance like running cron tasks, flushing disk cache, clearing the DNS cache, wiping out a stuck print queue, and more.
Link
Giveaway of the day — Portrait Painter 1.37 (Win&Mac)
NB: Please Follow Readme instructions carefully to activate the offer.
Portrait Painter is a revolutionary paint product that simulates a hand painted gallery-style portrait on fine linen or canvas. This professional painting tool will add color, light and texture, to your painting, which harmonize intelligently—and with stunning candor, to produce fabulous works of art that resonates with vibrant life.
Link
Game Giveaway of the day — Terrible puzzles
15 Simple puzzles on a mystical theme. Each level consists of 16 elements that must be rotated in the desired direction and dragged into place. At the beginning of the level, you see the image for 5 seconds, and then it disappears.
In this version of the game, the help button is disabled, which was in previous games, since the levels are very simple. The game has a choice of levels, and you can start the game from the level you choose.
Sometimes a spider appears on the screen that will distract you, you can get rid of it by clicking on it. The game will delight you with nice graphics and calm music.
Link
mfG
Trapped
Kein Support per PN/Mail
