Vidmore DVD Creator 1.0.30 & Animal World Puzzles
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Vidmore DVD Creator 1.0.30
Vidmore DVD Creator is an all-in-one video to DVD converter that creates DVDs from your video collections and also supports burning Blu-ray discs within one click. It supports a wide range of video formats, including MOV, MP4, VOB, MKV, AVI, WMV, etc. And it is fully compatible with all disc types, like DVD-9/5, DVD (NTSC or PAL), DVD+/-R, DVD+/-RW, and more.
This DVD burner also comes with a handy built-in video editor that lets you do some easy editing tasks before DVD burning. You can cut unwanted part from the video, rotate or flip the video to your desired angle, add subtitles, adjust video effects, and more. More importantly, its impeccable feature is the DVD customization options. You can personalize DVD menus and chapters, add background music, apply background pictures for your DVD & Blu-ray discs.
Special Offer: 40% Discount for Vidmore DVD Creator (Lifetime/3 PCs)
Link
Game Giveaway of the day — Animal World Puzzles
A science fiction-themed puzzle. Each level consists of 12 elements that will need to be rotated so that they match all the elements. The game has 10 levels. With each level, the pictures become a little more complicated. If you are in a difficult situation, then click on the E button, and the game will tell you where to place the desired item. In the game, you can scroll through the levels without passing them, if they caused difficulties in passing, just press the left arrow. The game will delight you with nice graphics and calm music.
Link
mfG
Trapped
Kein Support per PN/Mail
