Seite 1 von 1
Pazu Video Cutter for Mac & Leawo Photoins BG Remover 3.0.0.0 & OldPuzzles
Verfasst: Fr 11. Feb 2022, 09:09
von trapped
Giveaway of the day — Pazu Video Cutter for Mac
Pazu Video Cutter allows you to cut any video to small segments without quality loss.
Pazu Video Cutter for Mac makes it easy for you to losslessly split large video files to multiple segments by time, length or key frame. This video splitting tool supports almost all popular video formats such as AVI, MP4, MOV, M4V, MKV, MPEG, MPG, DAT, VOB, FLV, WMV, etc. Pazu Video Cutter's fast and accurate key frame cutting mode allows you to cut and trim any video files without re-encoding or quality loss.
Link
Giveaway of the day — Leawo Photoins BG Remover 3.0.0.0
Leawo photo BG remover is a smart photo editing tool that enables you to batch remove photo background with smart algorithms for batch output, and edit/change photo background manually for individual output. Erase background from transparent object, replace photo background with preferred picture or color, edit photo background, foreground and shadow, etc.
- Automatically remove background from images in batch.
- Accurately remove photo background with manual adjustment.
- Erase background from transparent objects on photo.
- Cut out hair and fur without skill and Photoshop.
- Change photo background easily.
Link
Game Giveaway of the day — OldPuzzles
A science fiction-theme puzzle. Each level consists of 12 elements that will need to be rotated so that they match all the elements.
The game has 15 levels. With each level, the pictures become a little more complicated. If you are in a difficult situation, then click on the E button, and the game will tell you where to place the desired item.
In the game, you can scroll through the levels without pressing them, if they could difficulties in passing, just press the left arrow. The game will delight you with nice graphics and calm music.
Link
