RecMaster Pro 2.0.852 & MobiKin Transfer for Mobile 3.1.47
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — RecMaster Pro 2.0.852
Discounted licences WITH UPDATES for giveaway users only (75% OFF)
RecMaster is a professional and useful screen recording software.
It supports accurate screen recording of any desktop activities such as desktop presentations & webinars, live webcasts, gameplays, Webcam videos with audios, and business meeting videos.
You can record full screen, gameplays, custom areas, as well as specific program window according to your needs. And the software also supports recording with the computer camera or webcam and recording audio only files. It allows you to complete the recording easily, efficiently and stably in different recording environments. It can also help you edit the recorded files by cutting, merging, adding subtitles, delogo, and more. With this screen recorder, you can also set recording format, resolution, frame rate, camera output, audio output, etc. separately so that you can record all kinds of video content you want. It is the best choice for your work, study and entertainment.
· One-click Made Screen Recording Simple
Built with seven screen recording modes, RecMaster will offer you the easiest and most efficient way to record your computer screen. Just one click from RecMaster, enjoy every moment and details from your computer screen.
· One-click for Multi-monitor & 4K Recording
RecMaster comes with powerful features, like HD recording, up to 4K recording, auto-start recording, picture in picture, schedule recording, multi-monitor recordeing, etc. It will offer you the best experience for screen video recording.
· Annotate & Edit Recorded Clips Easily
Built with annotations and editing tools, RecMaster allows you to annotate when recording. You can also add a custom text or image watermark easily. With the recorded videos, you can easily add subtitles and cut the videos in the simple editor. Ensure your recording video be perfect and instructive to your viewer.
· Movement Effects for Cursor
You can choose different movement effects or colors for the cursor. You can also set a click sound or different colors for right and left click. Thus, it offers your viewer a more effective guideline.
· Hotkeys & aoto-record videos at launch
With the hotkeys, you can easily start/stop/pause the recording, show/hide main interface, etc. And with the built-in schedualing tool, you can easily set to start or stop recording automatically.
Link
Giveaway of the day — MobiKin Transfer for Mobile 3.1.47
Wechselt ihr zu einem neuen Telefon und möchtet Daten vom alten Telefon auf das neue übertragen? Oder möchtet ihr einfach etwas zwischen zwei verschiedenen Geräten teilen? MobiKin Transfer for Mobile kann euch helfen, die Datenübertragung einfach abzuschließen.
MobiKin Transfer for Mobile Lifetime Lizenz mit 50 % Rabatt für GAOTD-Benutzer.
Link
mfG
Trapped
Kein Support per PN/Mail
