AnyMP4 Audio Recorder 1.0.12 & Roobrick
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — AnyMP4 Audio Recorder 1.0.12
AnyMP4 Audio Recorder is an easy-to-use audio recording program for computer. It records system sound from computer. Moreover, it can record your voice via microphone to create a narration for your presentation. Both the system sound and microphone audio recording are controlled separately. You can record either of them or both as you like.
Key functions and features:
1. Record audio on computer including web audio meetings, podcasts, and so on for personal use
2. Record audio from computer system sound and microphone separately.
3. Record audio as long as your hard drive is running up.
4. Clip audio recording to save the part you want.
5. Save audio recording as MP3, WMA, AAC, and M4A.
Only for Giveaway of the Day users, AnyMP4 specially provides a 50% off coupon: ANYGOTD (apply to recommended products and other products).
Link
Game Giveaway of the day — Roobrick
Logical, hardcore puzzle platformer with minimalist graphics, many interesting traps, puzzles spread throughout interesting levels. The main protagonist has the ability to change size, and will use this to pass the majority of traps and riddles by picking the right size. The longer the protagonist, the higher he can jump, and the wider, the more he can jump or fall on the spikes. Green artifacts give the hero more size variation capability. On most levels there are a lot of hidden secret areas, where the portal to exit, or secret passages may be hidden.
Link
mfG
Trapped
Kein Support per PN/Mail
