DMclone 1.4 (Win&Mac) & Surrealism Puzzle
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — DMclone 1.4 (Win&Mac)
Efficient Disk Cloning Software
DMclone for Windows is one of the best disk cloning software. It can help you securely and easily clone HDD, SSD, memory card, USB flash drive, etc from one location to another. You also can use it to help you upgrade old hard drive to a new one without reinstalling Windows OS.
Partition Clone Mode
The partition-level disk cloning mode. Clone a hard drive partition to a new hard drive partition or device or clone data from external device to your hard drive partition.
Disk Cloning Mode
The disk-level disk cloning mode. This mode can help you easily clone an entire hard disk drive to another hard disk drive or external device or clone data from external device to your hard disk drive.
Why You Need DMclone for Windows?
DMclone for Windows is 100% safe disk cloning software. It supports to clone any type of hard disk drive or removable storage device.
Reliable Disk Cloning Solution
Easily Upgrade Your Hard Drive
Easy Data Backup Software
Securely Replace Old Disk with SSD
Link
Game Giveaway of the day — Surrealism Puzzle
Surrealism Puzzle is a simple puzzle game that will help you relax after a hard day. The game is very simple, as it was created for your relaxation and does not require special attention. The game has 10 levels, where each level consists of 25 elements that must be rotated in the desired direction and dragged into place. At the beginning of the level, you see an image for 5 seconds and then it disappears. In this version of the game, the help button is disabled, as it was in previous games, since the levels are very simple. The game will help you relax and have fun. There is a choice of levels and you can start playing from the level you choose. The game will delight you with nice graphics and calm music.
Link
mfG
Trapped
Kein Support per PN/Mail
