PhotoScissors 9.0 & The Steampunk Era
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — PhotoScissors 9.0
PhotoScissors ist ein Tool zum Entfernen des Hintergrunds sowie zum einfachen Extrahieren von Objekten. Alles was ihr machen müsst, ist den Hintergrund vom Vordergrund zu trennen, den Rest erledigt das Programm. Kein spezielles Vorwissen erforderlich - nach einem paar Mausklicks ist alles perfekt eingefügt und die Nahtlinien können anschließend nachgearbeitet werden.
Link
Game Giveaway of the day — The Steampunk Era
The Steampunk Era is a slightly challenging puzzle game with 35 pieces and 12 playable levels. The game resumed the preview of the image before the game, you can see how the final image should look, after which it will disappear (5 seconds). In the game, you need to swap tiles in places to complete the image, as all the fragments will stand correctly, you will receive a notification that the game has been completed, and after 5 seconds you will move to a new level.
In this version, there is no transition to a new level if you have not completed the current level. The game includes one hint with which to simply start the game, the lower right fragment is marked with the "GameREA" logo. You won't be able to start the game from any level either. When you pass the level, the password for this level will be written at the bottom of the panel, from which you can start the game if you enter it on the passwords tab, which is located in the menu. The game is colorful and I hope you enjoy this format. Good luck to everyone in the game.
Link
mfG
Trapped
Kein Support per PN/Mail
