SilentRun Pro 1.0 & Adventure mosaics. Forest spirits
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — SilentRun Pro 1.0
SilentRun is a small and handy Windows system software tool that can easily let you run multiple programs silently in the background. It can hide program windows and interfaces, and increase or decrease the priority of background processes. For some programs with sound output, SilentRun can also mute the program then run it silently in the background.
SilentRun has a simple interface and is very easy to use. To run a program silently, simply drag the selection box in the upper left corner of the SilentRun window to the title bar or the window of the program that needs to be run silently. You will see the program is selected by SilentRun and a thumbnail of the program would be displayed in the preview area. (Some applications use the non-standard GUI and that might be displayed as a solid black square). After that, you can select the background silent running priority (the default is the "Normal" priority) under the preview area, and set whether to mute the sound output, and finally click the "Hide It" button. You can repeat the above steps to let multiple programs run silently in the background.
Link
Game Giveaway of the day — Adventure mosaics. Forest spirits
Exclusive offer from Giveaway of the Day and ToomkyGames! No third-party advertising and browser add-ons!
A girl lost her way in the forest, and now it's up to her to help the forest spirits and save the woods from the darkness!
200 colorful nonograms for any difficulty, enchanting storyline and magical music, a wonderful combination to help you pass the time! Improve your puzzle skills by solving nonograms.
Progress through the levels by solving puzzles and helping spirits decide their destiny!
- 200 colorful levels you won't soon forget!
- Stunning visual effects!
- House upgrade minigame!
- Enchanting storyline!
- Wonderful art painted with the best summer colors!
- Perfect logical and abstract thinking exercises!
- Easy to play, hard to put down!
Link
mfG
Trapped
Kein Support per PN/Mail
