Cleaning Suite Professional 4.009 & Dark Illusion
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Cleaning Suite Professional 4.009
If the system boots up more and more slowly and the hard drive gets fuller, then it is high time for a thorough system cleaning! But which data can be deleted without risk, which are still needed for the smooth system and program flow? Cleaning Suite gives the answer!
A total of six helpers analyze your system and enable deep cleaning operations. For example, you can delete temporary files, clean browser histories, caches, and cookies from all popular Internet browsers, and prevent installed applications and tools from starting automatically at system startup.
The Windows Registry can also be optimized by Cleaning Suite in a targeted manner. The Windows software proceeds very carefully to ensure unrestricted use of your computer even after the cleaning process. On top of that, Cleaning Suite provides advanced features for the Windows Recycle Bin.
A restore center provides the ability to undo certain actions of the software at any time. The detailed journal also provides information about the entire cleaning history.
Link
Game Giveaway of the day — Dark Illusion
A puzzle game that will immerse you in a world of scary stories. Take on the challenge and try to solve 10 levels, each of which consists of 20 elements. You have to put all the pictures in the correct order to open the button to go to the next level. Be careful, these puzzles are not so easy to solve! Show your skills and complete all the levels of this medium difficulty game.
Link
mfG
Trapped
Kein Support per PN/Mail
