AWZ AnyPorter Pro 3.1.0 & Forgotten Collections 3
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — AWZ AnyPorter Pro 3.1.0
AWZ AnyPorter is a powerful and user-friendly location spoofing software designed for iOS devices. Developed by AWZtool. It allows virtual GPS positioning to protect privacy on social media, change locations in games to access specific content or gain advantages, and test location-based applications. With AWZ AnyPorter, users can freely select any location worldwide and simulate movement as if they were truly there. The tool is easy to use, with a friendly interface, and is compatible with various iOS devices, providing users with more flexibility and control over managing their device's location. AWZ AnyPorter offers multiple modes, including multi-point mode, single-stop mode, and jump teleport mode, to meet different location spoofing needs. Additionally, it supports various location-based applications and social media platforms such as Pokémon Go, Tinder, and Instagram.
Link
Game Giveaway of the day — Forgotten Collections 3
In the third part of the game "Forgotten Collections" you will find 16 new levels with fascinating puzzles of 45 elements. Your task is to collect all the pieces to reveal the image of a unique object and advance to the next level.
You can select any level from the suggested list and start building. Before the start of each level, you will be presented with an original image of the object, which will help you recreate the picture correctly. If you need help, just click on the question mark button to get a hint.
If some level turns out to be too difficult, don't worry! You can use the arrow to move to the next level, even if the current one has not been completed yet.
After all the elements are correctly assembled, a notification will appear about the completion of the level, and the game will move on to the next stage, opening new puzzles of unique objects in front of you.
Each level starts with the first element of the puzzle, marked with an asterisk, located in the upper left corner to facilitate the assembly process.
Link
mfG
Trapped
Kein Support per PN/Mail
