ScreenBackTracker 1.0.1 & Acrophobia Ball
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — ScreenBackTracker 1.0.1
ScreenBackTracker ist ein Lebensretter-Tool, das euch daran erinnert, welche wichtigen Ereignisse in der Vergangenheit stattgefunden haben. Es notiert sich alle PC-Aktivitäten und ist somit ideal für unauffällige Beobachtung.
Link
Game Giveaway of the day — Acrophobia Ball
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
They say that when nothing goes right then go left! It may be true but sometimes it is even necessary to go upwards. This is the very thing that developers of Acrophobia Ball did. They just decided to give you a simple thing which only seems to be so. In reality it's not as easy as you might think. If you have any problems with balancing you will find it difficult to let your ball run without falling down. The difficulty is in the platforms which have such special shapes that you can easily lose the ball in some of the holes or just let it miss the line. And there is one more surprise for you - the action will take place in the sky!
Link
mfG
Trapped
Kein Support per PN/Mail
