Folder Lock 10.0.6 & Falco Chapaev
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Folder Lock 10.0.6
Folder Lock 10 is a powerful security software that helps you protect your sensitive data with advanced encryption and cloud storage features. It uses 256-bit AES encryption to secure files, folders, and drives, making them inaccessible to unauthorized users. With the Cloud Backup feature, you can store your encrypted files securely in the cloud and access them from any device, including PC, iOS, and Android. The software also offers portable lockers, allowing you to carry your encrypted files on a USB drive and share them safely with others.
Additional tools include password management, secure wallets for storing sensitive information, file shredding to prevent recovery, and privacy history cleaning for enhanced security.
Link
Game Giveaway of the day — Falco Chapaev
Falco Chapaev is a simple but exciting game where you have to push your checkers and knock out your opponent's checkers. For each checker successfully knocked off the board, you get points. In order to win the game, you need to knock out all the opponent's checkers from the board. Can you win the game Falco Chapaev?
Link
mfG
Trapped
Kein Support per PN/Mail
