Geekersoft Compressor 4.1.14 & Falco Bottle Sorting
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Geekersoft Compressor 4.1.14
Geekersoft Compressor has many advantages such as small footprint, high compression rate and speed, stable performance, and integration of multiple compression algorithms. In addition, it also offers multiple compression types. It also allows you to adjust the video output resolution, select output formats, batch compress files, and more.
Compress pictures
Accepts all popular image formats: BMP, JPG, JPEG, PNG, GIF, TIF, and TIFF.
Allows you to keep the image in its original format or save it as JPEG, PNG, etc.
Customize image size or clarity, etc.
Compress video
Supports multiple video formats: MP4, MKV, MOV, WMV, AVI, TS, etc.
Provides videos with various resolutions, such as 1080p, 720p, 480p, etc.
Change the compression quality of the video, etc.
You can preset the video size before compression.
Fast and stable
This file reducer adopts the most advanced compression technology, which can ensure low consumption of system resources and fast compression speed.
High compression ratio
Compared to other similar compression programs, Geekersoft Compressor Treasure can compress files at a higher rate and output them with better quality.
Batch compression
If you need to compress a large number of files simultaneously, simply upload files in bulk, wait for compression, and then download the files. It's that simple!
Link
Game Giveaway of the day — Falco Bottle Sorting
Falco Bottle Sorting is an engaging and relaxing game where you need to sort bottles by color!
To complete a level, you need to have 3 bottles of each specified color. Use the left mouse button to select a bottle.
Will you be able to correctly sort all the bottles in the game Falco Bottle Sorting?
Link
mfG
Trapped
Kein Support per PN/Mail
