Hard Drive Optimizer 1.8.1.11 & Puzzle Pop
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Hard Drive Optimizer 1.8.1.11
Find the largest files on your hard drive and delete the ones you don’t need the easy way. With Hard Drive Optimizer, you’ll recover free disk space in no time!
- Instantly Find Large Files.
- Built-in Disk Defrag Source.
- Improve Disk Performance & Lifespan.
Link
Game Giveaway of the day — Puzzle Pop
Puzzle Pop is a bright and fascinating head game in which players strategically place multi-colored figures on the 8x8 grid to clean the rows and columns. Select the figure in the pre -viewing area, then click on the net to place it. Glasses are awarded for cleaning lines, and the goal of the game is to gain 100,000 points to win. Each movement generates new figures, but if there are no suitable places for placing figures, the game ends. Thanks to the intuitive control and increasing complexity, Puzzle Pop checks your spatial skills and the ability to plan. Can you master the grid and achieve victory?
Link
mfG
Trapped
Kein Support per PN/Mail
