Leawo Music Recorder 2.0 & Ashampoo Uninstaller 2017
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Leawo Music Recorder 2.0
As a highly-praised audio recording software, Leawo Music Recorder can help music lovers easily get any audio source. It can act as streaming audio recorder to record Mic audio and other built-in input audio stream. It can also serve as a computer audio recorder to record computer audio files in local music library. The recorded audio can be saved into MP3 or WAV format as users like. With the assistant of the recording Task Scheduler, this music recording software allows users to schedule recording upon preset recording start time and recording duration. Leawo Music Recorder can also automatically download and add music tags like album, album cover, artist, song name, etc. to the recordings.
Key features:
Records audio and music from computer audio and online music sources like AOL Music, Last.fm, etc.;
Records Mic or other built-in input audio stream like Realtek High Definition Audio, Realtek Digital Input, etc.;
Recording Task Scheduler sets recording start time and recording duration;
Records audios of any built-in input or computer stream audio and save in MP3 or WAV format;
Automatically downloads and adds music tags including title, artist, album, year, genre and album artwork to recordings;
Supports manual music tags editing with a built-in music tag editor;
Sets time gap to let this music recording software automatically filter or split recordings;
Play back recordings for preview and create, edit or delete playlist for recordings;
Apply recorded music files to iTunes music library with one click.
Link
Giveaway of the day — Ashampoo Uninstaller 2017
Ashampoo UnInstaller 2017 removes software completely without any leftover files, even in the case of nested setups. The program meticulously logs new installations to record any modifications to your system. This allows users to uninstall unwanted programs that were installed during normal installations without their knowing. Another useful feature is snapshots which can be used to compare the state of a system at different points in time. UnInstaller 2017 is light on system resources and does not slow down your machine.
Please note: The program is made as a part of Ashampoo UnInstaller 6. A unique upgrade price for GOTD users: $23.99, instead of $59.99.
Link
mfG
Trapped
Kein Support per PN/Mail
