Ai Character Prompt Builder & Falco Apple Worm
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Ai Character Prompt Builder
What This Tool Does
This Google Sheet helps anyone generate fully detailed, ready-to-use character prompts with a few clicks. No writing, no guesswork, no prompt engineering needed.
Use it to create:
Viral social media character prompts.
Custom prompts for clients.
Prompt packs for Etsy / Gumroad.
Content for YouTube, TikTok, Instagram.
Personalized character gifts.
Branded character avatars.
Why It’s Useful
Good prompts are in high demand, but writing them takes time.
This builder handles everything automatically.
Dropdown selections for each character detail.
Smart fields build your prompt for you.
Copy-paste output ready for ChatGPT, DALL·E, or Midjourney.
Beginner-friendly.
Fully customizable.
Rebrandable.
You get a working business tool — not just a prompt!
Link
Game Giveaway of the day — Falco Apple Worm
Help the worm to get to the apple! It seems simple, but his path is intricate. If you do the wrong thing, the worm may get stuck or fall. Beware of saws and ice peaks. Push rocks to get where you couldn't before. Every time you eat an apple, it increases the size of the worm, which can not only help you climb higher, but also have negative consequences. Be careful and you will succeed.
-Interesting gameplay
-Dear worm
-Challenging levels
Link
mfG
Trapped
Kein Support per PN/Mail
