MP3 Hammer 1.0 & Azteca
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — MP3 Hammer 1.0
MP3 Hammer is a handy, yet easy-to-use, program built for one core purpose: batch bursting long MP3 files into smaller, manageable, and precisely timed segments. Unlike generic audio editors that force you to manually set start and end points for every cut, MP3 Hammer automates the entire process, allowing you to slice large audio files based on a fixed duration you specify.
When you think of a hammer, you think of force, precision, and the ability to break apart larger things into smaller, manageable pieces—or to drive parts together with clean, finality. The long, cumbersome MP3 file is the "monolith." It’s big, unwieldy, and hard to manage. MP3 Hammer takes a large, unbroken stream of audio and decisively smashes it into smaller, precise segments.
Key Features That Make MP3 Hammer The Solution:
Batch Processing for Ultimate Efficiency
You don't have to process files one by one. MP3 Hammer supports true batch processing, allowing you to load dozens of long MP3 files simultaneously and apply the same splitting rule to all of them in a single operation. This saves countless hours compared to manual trimming.
Preserves MP3 Quality
Crucially, MP3 Hammer performs the splitting function by directly cutting the MP3 stream at the specified duration markers. It does not re-encode the audio. This means the output pieces retain the exact original quality—bitrate, sample rate, and fidelity—of the source file, with no generational loss of audio quality.
Support Most of Popular Audio Format
Besides MP3, the program supports the most of popular audio formats such as WMA, OGG, WAV, FLAC, AC3, AAC, AMR and MPG.
Intuitive User Interface
Despite its powerful functionality, MP3 Hammer features a clean, straightforward interface. The workflow is simple: drag-and-drop your files, input your desired duration, and hit 'Hammer It!'. It’s designed to be effective for both complete beginners and power users.
Link
Game Giveaway of the day — Azteca
Exclusive offer from Giveaway of the Day and ToomkyGames! No third-party advertising and browser add-ons!
For this challenging riddle, you'll need a quick eye and tactical skills to move forward. You'll need to think outside the box to make it very far, but plenty of advantageous bonuses will help you. You have to be quick to collect all the missing words and solve the ancient mystery. Time is against you in Azteca.
150 levels
Awesome power-ups
Special effects
Link
mfG
Trapped
Kein Support per PN/Mail
