Wise Folder Hider PRO 3.41 & Dramatic Black & White 2.55
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Wise Folder Hider PRO 3.41
Wise Folder Hider Pro can hide files and folders on local partitions or removable devices. The files will be hidden safely due to advanced encryption algorithm. You can set a password for it so that the hidden data can be displayed and unhidden only by entering the valid password. The data is completely invisible to other programs or on other operating system, so it is much more reliable. Compaired to other folder hiders, Wise Folder Hider Pro is more secure and convenient for users to modify protected files. Moreover, the interface of Wise Folder Hider Pro is very intuitive. Even a first timer can get the hang of it in a minute.
NB: The license is provided for 1-year; supports upgrading.
Link
Giveaway of the day — Dramatic Black & White 2.55
Everyone knows it doesn't get better than classic Black & White - it is the artistic soul of photography. And Dramatic Black & White is the best at it.
Using Dramatic Black & White, you can make your own black and white photographs, ones where light and contrast, grit and form come together to tell a story; where stone and sky, water and light transcend the material world and ascend to the Photographers' Gallery.
Includes:
Black & White—creates a classic photo with filters for RGB refinements;
Infrared—creates a modern photo filled with extrodinary lighting;
Dramatic Black & White—creates a high defintion photo for drama.
Link
mfG
Trapped
Kein Support per PN/Mail
